5th Wheel Towing
Old Mar 19, 2009 | 04:55 PM
Scottk250sd's Avatar
Scottk250sd
5th Wheel Towing
I've got a 2004 6.0 PSD CC FX4 - I'm pulling a 35ft 5th wheel that is 12K dry.. Is that overloading my truck to much? the truck looks level when it's hooked up and I just have the stock Rancho shocks on it..
Thanks..
Old Mar 19, 2009 | 05:49 PM
UGA33's Avatar
UGA33
You will be fine. Just make sure you can stop it.
Old Mar 19, 2009 | 06:06 PM
69cj's Avatar
69cj
Ditto Smokey, just make sure those trailer brakes are in good shape and the brake controller is set properly.
Old Mar 19, 2009 | 07:36 PM
Delawhere?'s Avatar
Delawhere?
Thanks..
Just an FYI, you might take the 35ft 5th and go to a scale at a truck stop. Check the weights before and after you have it loaded. The scales at the Cat scales near me charge $8 for one and $11 for two weighs. I usually check the truck and trailer seperately, then hook up and recheck the total and you can see the hitch weight on the truck. It's a good check to see if the manufacturers suggested weights are actual weights, the brochures are often wrong. Happy Camping
Old Mar 19, 2009 | 08:19 PM
mackman's Avatar
mackman
Ditto My 05 SD pulls a 36 ft Jaco that dry is 11,500 and 15,000 loaded. I have the 10,000 lb GVW option . Truck don't know its there
Old Mar 19, 2009 | 10:55 PM
southbound35west's Avatar
southbound35west
check my signature pic and my other pics, i pull a monster 38' ,15,500lbs 5th wheel with my f250, it handles it..................just do not swerve when towing that top heavy load at a high rate of speed
Old Mar 20, 2009 | 09:21 AM
Scottk250sd
Thanks for all the good info.. I think I'll hit the scales next time out just out of curiosity.
Old Mar 20, 2009 | 11:21 AM
steelhead2's Avatar
steelhead2
dang!!!!! and i'm concerned about pulling a 30ft trailer with my 04?.your 5'er is a monster!
Old Mar 20, 2009 | 12:50 PM
southbound35west
sometimes it does not feel very stable when towing it with my f250..............it mainly gets towed by a dual tire rig now..........
Old Mar 20, 2009 | 11:11 PM
bfrd22's Avatar
bfrd22
Up until 26 hrs ago I was pulling my 33ft 11,500 lb 5er with a 2500HD 6.0 Gas and did pretty good. Now with the new (to me) F350 6.0 it will be a snap!
Old Mar 25, 2009 | 08:28 AM
salty's Avatar
salty
I have been towing my 39 ft copper canyon fifth wheel with a 03 chevy 2500HD 6.0L gas crew cab short box with no problems. I can tell the truck is a little light for the camper so I bought a 04 F-350 6.0L SW crew cab short box lariat yesterday. I am also upgrading my camper to a forest river sierra 375QBQ 4 slide which has an overall length of 40'
