banks trans command
Old Mar 19, 2009 | 03:27 PM
88f150302's Avatar
88f150302
banks trans command
has anyone used this how did it work?
Old Mar 20, 2009 | 09:18 PM
mustangman02232's Avatar
mustangman02232
a real shift kit (trans go or B&M) would be prefered, the trans command is electric which adjusts line preasure on the shift, a shift kit is working the valve bodies in the tranny.
i have a shift kit in mine that the previous owner had put in when he rebuilt the tranny before i baught the truck, either one will be better then stock though.
Old Mar 20, 2009 | 09:27 PM
George D.'s Avatar
George D.
I recomend doing a shift kit and a new style line presure modulator. As long as you understand the concepts of righty tighty lefty loosey you should be able to put a shift kit in. Also you could check in the 94.5-97 fourm and search coon trany mod. Coonhunterjoe up there drilled 3 1/16" holes in his valve body to make it shift firmer.
