Sponsored by: Real Truck
Master Pro or Moog ball joints
Old Jan 17, 2011 | 04:34 PM
gearloose1's Avatar
gearloose1
An issue that I turned with with wheel bearings that I am sure have now infiltrated front end parts:
Counterfeit parts.
Really know who your suppliers are... that means no eBay parts at apparently ridiculously low prices for name brand.
Good luck.
Old Jan 17, 2011 | 04:57 PM
warriorm's Avatar
warriorm
Originally Posted by 03shadow350
i saw that dynatrac has there own ball joints . not sure if they are on the market yet. i bet they will cost some $$$$$.
I believe $599 for 2 uppers and 2 lowers. The following is from Dynatrac's web site.
Benefits
  • Reduce the cost of operating your truck.
  • Big increase in strength from the OEM ball joints.
  • Rebuildable without special tools – Lower repair costs.
  • Long Life – Less downtime, less tire wear.
  • Improves performance, handling and driver’s feel of the road.
Features
  • High strength billet steel and heat treated bodies.
  • Super strong cromoly steel, heat-treated stems.
  • Effective seals prevent contamination and promote long ball joint life.
  • Fully greaseable on the truck.
  • Heat treated, precision ground stainless steel ball conforms to Military specifications.
  • Teflon coated internal wear points.
  • Fully-adjustable cup support protects against severe road impacts.
Old Jan 17, 2011 | 05:39 PM
2002 F350V10's Avatar
2002 F350V10
Moog is the name brand with a quality reputation. The other one is a generic house brand. Usually in relation to the question how long do you plan to own the truck.
While recently doing lower ball joints on a car, my first parts source had only 1 ball joint in stock. The next stop, had the other in a different brand. When I went to put them in, one box had another box inside of it which matched the first one I bought, and both ball joints were actually the same manufacture.
sixty4chevrolet
May 1, 2016 07:09 PM
Olafs 7.3 ex
Apr 10, 2016 02:41 PM
rookieford
Feb 15, 2016 08:56 PM
Metz22
Sep 2, 2015 06:45 PM
birchy
19
Aug 21, 2009 08:09 PM
