sca's
Old Mar 21, 2009 | 01:17 PM
George D.'s Avatar
George D.
Yup I had no compresion inm the radiator on mine and it would only occationaly lock up at first.
Old Mar 21, 2009 | 02:37 PM
dyoung14's Avatar
dyoung14
[quote=Dave Sponaugle;7289558]Is it loosing coolant.
Deopending on where the hole in the cylinder is, the coolant may be on top of the piston or go straight into the oil pan.
The engine will only hydrolock when coolant is on top of the piston.
And if you just bump the starter or if the engine sits long enough the coolant will leak down to the oil pan and the engine will run normally.
If the cavitation hole is low in the cylinder you may not even see compression in the radiator.[/quote
i have noticed its loosing kinda a tiny bit, but the radiator cap on my dads truck dont have the rubber seal, so i figure thats were the coolant is going and there is no pressure also cause there is no seal on the radiator cap
Old Mar 21, 2009 | 03:27 PM
starmilt's Avatar
starmilt
Radiator caps are cheap.
Old Mar 21, 2009 | 06:20 PM
dyoung14's Avatar
dyoung14
my dad is cheap to lol
Highboy74
Sep 13, 2012 08:34 PM
scottie2hottie
Offroad & 4x4
Feb 1, 2008 09:31 AM
manofmanyfords
Feb 19, 2006 03:06 PM
xmxcubedxmx
1983 - 2012 Ranger & B-Series
Oct 9, 2004 06:57 PM
wbandyjr
Dec 15, 2002 04:53 AM
