Sponsored by: Kumho
ABS Issue
Old Mar 19, 2009 | 11:49 AM
Turbotim2's Avatar
Turbotim2
ABS Issue
I have posted on a couple of other threads and have not recieved much info, though I'd try here.
1997 F250 Heavy Duty, 4x4, 460 gas, RABS (II I think). The abs light came on and diagnosing it, got the code 12. As far as I can see, the 12 means that abs EBCM is having issues. I have a Haynes manual which doesn't even mention the part, nor have I been able to locate one at parts stores. One person wrote that it is located behiind the ashtray on the firewall, I haven't dug into it yet since I can't find a replacement. Does anyone have any leads? I have also searched the web and have found nothing about it. Sure appreciate any help!!
Old Jun 7, 2009 | 06:25 AM
Turbotim2's Avatar
Turbotim2
Bump - anyone?
Old Jun 7, 2009 | 07:37 AM
Lazy K's Avatar
Lazy K
On the `97 models the computer is, I think, behind the glovebox. Unfortunately I only have a list of codes for the earlier system and 12 is a defective computer module but I would not be sure for your system.
If you do need one you could try directfordparts.com for OEM.
Old Jun 8, 2009 | 06:02 AM
Turbotim2's Avatar
Turbotim2
Thanks for the reply Lazy K, do you know if this is the computer that controls the engine as well or is this a seperate unit that just controls the ABS? Thanks!
Old Jun 8, 2009 | 07:02 AM
Lazy K's Avatar
Lazy K
The RABS is a complete stand alone system, the computer that controls it is seperate from the engine one. The RABS and engine do not share any systems.
Old Jun 8, 2009 | 07:13 AM
Turbotim2's Avatar
Turbotim2
OK, thats what I thought. I have looked for the part and have come up empty handed. I guess I'll try the junk yard.
Old Jun 8, 2009 | 12:47 PM
Lazy K's Avatar
Lazy K
RockAuto has them at around $80 plus core, a bit more if you want new rather than reman.
