Weird problem after tensioner stud broke.
Old Mar 19, 2009 | 01:52 AM
fonefiddy's Avatar
fonefiddy
The tensioner stud broke while driving. I pulled over and unwound the serp belt. Luckily no damage to radiator, fan clutch, etc.
But after replacing the alt/air pump bracket, and the tensioner, the alternator warning light is lit. The gage reads normal. Like it's charging. When I hit the PW switch it jumps just like normal.
Is the alt damaged? Over charging?
Old Mar 19, 2009 | 03:37 AM
pnp522's Avatar
pnp522
I had the same problem. It was a loose connection at the plug on the side of the alternator. It had to be pushed or wiggled a few times whenever anything was done on the truck. The light would stay off after a few times. After the alternator was replaced went front bearing out no more problem.
Old Mar 19, 2009 | 09:19 AM
fonefiddy's Avatar
fonefiddy
Yep, I just went out and cleaned the connex. Light is out now.
Thanks
