Sponsored by: Real Truck
Trailer lights question
Old Mar 18, 2009 | 09:56 PM
f-4x4's Avatar
f-4x4
OK i have a 02 super duty. The truck has a problem with the trailer lights (the lights in the truck its self work fine) Any way everything on the trailer lights side works fine with the exception of the right hand stop/turn signals. I am checking this with a test light. Is this a fairly common problem? Help me out guys.
Thanks matt
Old Mar 19, 2009 | 01:16 AM
twags6's Avatar
twags6
The trailer lights are fused separately from the truck. There should be one for the parking lights, left turn/stop and right turn/stop. On the 01, they're the small fuses located in the fuse box under the hood. I dont know if they're in the same spot on the 02 though. Check the owners manual for the location.
Old Mar 19, 2009 | 01:48 PM
jbrianas's Avatar
jbrianas
my 05 f350 developed a sticky relay for the right side trailer lights,
it was sporatic in operation and would stick on at times
you might want to check that as well. its under the hood in the fuse/relay center
g/l
Old Mar 19, 2009 | 03:41 PM
f-4x4's Avatar
f-4x4
ok thanks. the trailer light fuse for my truck is for the left and right stop and turn signals. and i dont know if there is a relay under the hood on 02 but i will check.
Old Mar 19, 2009 | 06:53 PM
f-4x4's Avatar
f-4x4
is that the relay box under the hood with onil 3 relays in it?
Old Mar 19, 2009 | 09:12 PM
texan2004's Avatar
texan2004
Make sure you have a good ground on the trailer light that doesn't work. I suspect that is your problem and the truck is fine.
Old Mar 19, 2009 | 10:25 PM
blue06's Avatar
blue06
Had a similar problem with my O6 a month ago and it turned out a rental trailer I used had a short and it burned out two fuses in the fuse block under the hood..
Good luck in your search for the problem
Old Apr 4, 2009 | 09:35 AM
RFD_Truckie's Avatar
RFD_Truckie
I too have an 02 250 with a similar problem. The Trailer stop/turns (both sides) dont work. Tested with a light.... Nothing.... Tested with a voltmeter.. very low voltage (3-4). I have traced the wires all the way up to the truck, and the next step is behind the fuse panel. My trailer brakes also have low voltage but sometimes they work. I was told the relays for the 02s trailer turns is a PITA and is behind the dash somewhere. I am hoping that I just have some corrosion issues behind the fuse panel as that is gonna be easier than getting to the relay.
As soon as I get it figured out, I will post it. If you get yours figured out, post it or PM me so I can check that also.
THanks
Hab
Old Apr 4, 2009 | 06:43 PM
texan2004's Avatar
texan2004
THanks
Hab
It's a fuse inside the truck but not one of your mini fuses. It's one of those tall square ones. It's blue. I can't remember the amp rating on it. Check it with a multi meter when you pull it. Often it looks good but it's catualkly fried where you can't see it. I've had this one go out on me more than once.
Old Apr 5, 2009 | 08:12 AM
RFD_Truckie
The tall blue fuse, Is that in the fuse panel or on a sub panel somewhere? I did not check those with a meter, just a visual.
Thanks
Hab
Old Apr 5, 2009 | 09:06 AM
texan2004's Avatar
texan2004
It's in the main fuse panel below and left of the steering coulumn inside the cab.
Old Apr 5, 2009 | 09:13 AM
RFD_Truckie
Thanks.... Hopefully thats the issue.... That would be an easier fix than I was figuring on.
Thanks agian
Hab
Old Apr 5, 2009 | 10:54 AM
Irelands child's Avatar
Irelands child
I just went through that with my '06 with a U-haul car hauler POS and in fact I have a post a ways along in this forum about the ordeal. A 75 cent 20 amp mini fuse in the underhood box fixed the problem but only after I hauled an expensive street rod 550 miles (gulp) with no turn or brake lights. I thought it was the 7/4 pole connector until I found that it is wired directly to the box and was in good shape.
Old Apr 5, 2009 | 11:00 AM
texan2004's Avatar
texan2004
There is a mini fuse that will go bad as well but I thought he said he had checked that one already.
RFD_Truckie
Ireland... I think I saw your previous post. I too had thought it was the connection point. I have check all the minis with a meter, but not any of the others. I know the feeling, I ended up towing my camper quite a distance without turns or brakes and my brake controller working intermittantly. What really stunk was the 3 mile 10% grade (downhill of course) the controller decided it was time to take a break. So it was OD off, and slow.
Thanks for the replies
Hab
