The torque converter is closer to the engine, those are clutch packs, planetaries and the rest of the transmission internals. The torque converter is in the bellhousing, closer to the engine from what's in your pictures. There's probably a dust shield that needs to be removed to see the torque converter and flexplate.
Do these transmissions not use a valve body anymore?
If it's in the bell housing then what are these people talking about. I dropped the pan removed the filter and then i assumed the torque converter was above that.
The only other thing on the bell housing right before the oil pan is a small plate. I remove that and all i can see or have access to is a very very small portion of the flywheel
I put 12 and 1/2 quarts in and no leaks but a slight drip from the dust cover plate and then i went to drive off and it sprayed from there according to my wife who was watching; luckily it didn't lose to much. The only cause of this would be that I did not tighten the drain plug on the torque converter enough correct?
Reason: word swap
their is a dust cover under the bell housing pull that and then you will see the torque converter...its a big round thing that goes from the flywheel to the trans.
hello,, i have a 92 f150 4x4, 351w with the E40D auto. trans. is it posible to switch a 2 wheel drive trans. in its place..? would i have to change anything..? thanks
ps) i found a 20 bolt metric, with overdrive, same as mine except from a 2 wheel drive
Reason: more info...
