Gauge Advice Needed
Old Mar 18, 2009 | 06:21 PM
pdx02's Avatar
pdx02
Gauge Advice Needed
I am finally adding a 4 gauge set-up on the a-pillar. I have two gauges for fuel pressure as well as my veg tank fuel level that came with my vegistroke kit. I need to know which 2 of these three choices you guys think is most important to have. i have a dp tuner, as well as exhaust and intake done. i dont do alot of heavy towing right now buyt may in the future do some towing. I am trying to choose between two of the three with choices being pyrometer, boost, and/or tranny temp. The gauges that vegistroke supplied are autometer with the bushed aluminum faces and look pretty slick. Any and all thought are greatly appreciated!
Old Mar 18, 2009 | 06:33 PM
superduty4x4's Avatar
superduty4x4
If you can only have one, I vote for pyro.
Old Mar 18, 2009 | 06:39 PM
pdx02's Avatar
pdx02
What if you could do 2?
Old Mar 18, 2009 | 06:43 PM
danskool's Avatar
danskool
Go Bills !
I vote , Pyro, Tranny
Old Mar 18, 2009 | 07:17 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I agree, pyro and tranny. Boost will tell you some things, but you need to know what is going on with your truck.
Old Mar 18, 2009 | 07:21 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Pyro and trans!
Old Mar 18, 2009 | 11:48 PM
CSIPSD's Avatar
CSIPSD
Pyro and tranny temp... They should have been your first gauges.
Old Mar 19, 2009 | 12:04 AM
robs01f250's Avatar
robs01f250
Pyro and transmission they will tell you alot more than a boost gauge will
Old Mar 19, 2009 | 12:09 AM
Full Throttle's Avatar
Full Throttle
I agree, Boost is fun to watch; but it really does not tell you to pull your foot out of it like the pyro and tranny do!
FT
Old Mar 19, 2009 | 12:26 AM
JockD's Avatar
JockD
Do you need to monitor both fuel pressures at once? If not, how about a 2-position selector switch for one gauge. This would open up a hole for the boost gauge.
Old Mar 19, 2009 | 02:20 PM
pdx02's Avatar
pdx02
The fuel pressure is actually going to monitor veggie fuel pressure and the fuel level is for my 40 gallon veggie tank. What temp range do I want for the pyrometer? Looks like there are two options. 0-1600 or 0-2000. What do you guys think about the color of the gauge faces. The ones vegistroke supplied are brushed aluminum. I have the limited with the tan 2 tone interior. I was thinking black faced gauges but I think that the silver might look at little better.
Old Mar 19, 2009 | 03:21 PM
just another truck's Avatar
just another truck
Dont ask me, I went with a stock look, and everytime I see somthing different I have wished I tried that......
Old Mar 20, 2009 | 03:10 PM
pdx02's Avatar
pdx02
Ok so I am going to have these gauges. Pyrom, Trans, Veg fuel pressure, and veg fuel level. Now I need to decide what order to put them in from top to bottom. Give me your suggestions!
Old Mar 20, 2009 | 03:21 PM
miller_feed
Pyro on top. Trans next. The other 2 on the bottom in the order you want.
Old Mar 20, 2009 | 03:22 PM
pdx02's Avatar
pdx02
I would think veg fuel pressure and then veg fuel level on the bottom.
