90xxx 302w
Old Mar 18, 2009 | 05:20 PM
guitarnik's Avatar
guitarnik
90xxx 302w
i am getting an original 71 302w with original 90XXX miles. is it true that you have to run the lead stuff thru these because of the valves? i am going to rebuild it eventually but i might run it stock first just for kicks.
Old Mar 19, 2009 | 10:54 AM
Beanscoot's Avatar
Beanscoot
Unleaded fuel for early 302
I remember being worried about this issue back when Tetraethyl lead was phased out. I have a 1969 351W in a car that of course did not have hardened exhaust valve seats. But I 've put on many thousands of miles on it since then, with no problems. I haven't used any additives, just the cheapest or second cheapest grade of unleaded gasoline.
I think you will be fine. When and if you rebuild it in the future you can look at the valves and seats and install hardened seats if there are signs of recession. In the valves that is, not the economy.
Old Mar 19, 2009 | 04:51 PM
guitarnik's Avatar
guitarnik
thats what i thought. thank you
Old Mar 19, 2009 | 06:25 PM
Conanski's Avatar
Conanski
Depending what the motor is from it could be high compression by todays standards, so it will want higher octane fuel.
Old Mar 20, 2009 | 06:21 AM
Freaksh0w's Avatar
Freaksh0w
I read a lot of the older 302 that used to run on leaded gasoline will ping on today's gas unless you use 93 octane. Sure, depends on the engine, but that was the general consensus. It definitely won't hurt to try.
Compression is important. Now, I have a 1950 Ford 8N that has been running on 87 octane for my 23 years of life, and it still cranks on the first try. Sure, 6 or 6.5:1 compression ratio... So I don't have much to worry about in the way of pinging.
Oddly, the ONE time I put a couple of gallons of 110 leaded gasoline in it, it gained a good amount of power. And I love the smell of racing fuel :-)
