my truck vibrating
Old Mar 18, 2009 | 02:37 PM
78f-onefifty's Avatar
78f-onefifty
my truck vibrating
i have a 78 f-150 2-wheel drive truck when i get to about 60-mph the truck vibrates a little than 65 and vibrates more than about 75 to 80 it stops it did this a while back and the tail shaft in the trans blew out can this be the drive line can i get it balanced OR something let me know what you think ! !! !
Old Mar 18, 2009 | 02:45 PM
ShamelessMT's Avatar
ShamelessMT
Yep, could be driveline out of balance, could just be a bad u-joint, could be a bad yoke. Any of those will cause vibrations. You should do a visual check of the driveline and check the u-joints. You can get the driveline checked and balanced at any drivetrain shop if you think it's needed.
Then again, it could be a tire out of balance...
Good luck.
Old Mar 18, 2009 | 02:55 PM
lew52's Avatar
lew52
The drive shaft u joins will do that..Do you feel it in the seat is rear..In the steering wheel front...Tire balance will do the same thing .. Lew
Old Mar 18, 2009 | 03:27 PM
78f-onefifty
i just put new u-joints in it and when the truck's trans blew up the yoke was stuck in the trans and i can't even beat it out i think that's the problem because my brother drove it like that for a long time prod like a year than i bought it and i than (BM)
