Sponsored by: Real Truck
sticky steering issues
Old Mar 18, 2009 | 08:51 AM
jdunbar's Avatar
jdunbar
i am close to changing my steering box but wanted to run my symptoms by everyone to make sure i'm making the right move. my 2002 f350 crew cab 4x4 w/ 6 inch lift sometimes won't turn when sitting still in my gravel driveway. i have to move foward or backwars to get the steering wheel to start turning. also the steering seems a little sticky when cornering. it doesn't return to center like it should. i have already tighnede the steering box to take the play out of it. went 1/8 turn at time to make sure it's not too tight. it was loooose! steering feels nice and tight now! steering box shot? 100k on truck.
Old Mar 18, 2009 | 10:07 AM
03_PSD's Avatar
03_PSD
do you get alot of ps whine when your turning or applying brakes?
Old Mar 18, 2009 | 10:09 AM
ReAX's Avatar
ReAX
With the 6" lift, I'd suspect your running 37" tires. 37" tires are going to be difficult to turn to begin with, having the calipers locked down on the rotor so the tires can't shift will make matters worse. So I'd suspect the hard to turn while stopped to be some what normal to indicative of needed a P/S fluid flush.
Not centering up while driving is either a caster issue or resistance in the gear box. Take a long look over the other steering components, but I'd suspect the gear box too from the information you have.
Old Mar 19, 2009 | 08:20 AM
jdunbar's Avatar
jdunbar
no whining whatsoever. i am running 35" tires. i have changed every tie rod and end on the front of the truck. also changed one side ball joints (other seemed fine). all this made a huge difference. i don't think there was anything wrong with tie rod ends, just wanted a piece of mind. whoever had this truck before me drove it hard. i have everything looking good now. just ant to get the steering back to as close to new as possible.
Old Mar 20, 2009 | 02:08 PM
mikesmayhem's Avatar
mikesmayhem
Mine sometimes gets stiff too and I usually just have to re-grease all the front end parts
and it seems to go away. It was a lot worse before I redid the front end.
Old Mar 20, 2009 | 03:34 PM
chris60's Avatar
chris60
mine was like that, the orig ball joints had dryed up. Ford had a TSB about testing it with the weight on it. Also, I know some guys with Diesels have hydra lock or something to that effect, foot on the brake, not enough boost left for the pwr assist. I would not be in a hurry to change out the steering box.
Old Mar 21, 2009 | 10:45 AM
chris60's Avatar
chris60
sorry, its hydro boost.. info from my shop manual
The power steering pump provides the fluid pressure to operate both the hydraulically-powered brake booster (hydro-boost) and the power steering gear.
Old Mar 21, 2009 | 01:44 PM
1bddelx's Avatar
1bddelx
Mine does the same thing. I run 37x13.50 tires. Ford changed the steering box already and there was no difference on mine. I have to idle slowly forward or reverse with no brake to turn my wheel easy.
Old Mar 21, 2009 | 07:24 PM
ayden2004's Avatar
ayden2004
I don't have a lift on my truck so this reply might not help. but on the failure to return when cornering issue. my truck did that last year. only it had gotten to the point where it wouldn't return at all. turned out to be a siezed up ball joint on the passenger side and a bad u-joint on the drivers side
