'74 temp gauge reading
Old Mar 18, 2009 | 08:27 PM
will_reed's Avatar
will_reed
Originally Posted by wb6vvv
I knew somebody would flame me over this. I totally agree with the use of laser thermo’s. I have found them to be very inaccurate, but I will call you on putting the candy thermometer into the coolant through the radiator cap. Take a good look at where the coolant is at under the radiator cap. It is right next to the top hose. That is the hose that is connected to the thermostat that lets the water out of the engine. The thermostat is right next to the sending unit for the temperature gauge. How much closer could you get? I have made numerous measurements throughout the years and there isn’t enough difference between the coolant temperature in the top tank of the radiator and the engine block at the temperature sender to note the difference with non-laboratory equipment. The man said he didn’t want to clutter up his dash with a bunch of after market gauges, so I gave him a simple solution to find out approximately what temperature the engine was running at when the gauge was between halfway and ¾ as he asked for. He didn’t ask for a lesson in physics. All he wanted was to know was if his engine was running too hot or normal. I gave him a simple solution to find out if his truck was boiling over or running normal. He doesn’t care if his engine is running at 185 or 196.38567 degrees. He just wants to know if it is normal or boiling over, so lets not complicate the issue with a bunch of engineering lingo.
Guys, I don't want to start a war. But, I do agree with the post above. A good estimate is all I need.
Old Mar 18, 2009 | 08:31 PM
Thudpucker's Avatar
Thudpucker
I like the lesson in Physics. Thanks Fmc400!
