6 Trouble Codes
P0472 Exhaust back Press. Sensor circuit low input
P0500 vehicle speed sensor (vss) malfunction
P0603 PCM processor keep alive memory error (KAM)
P0478 exhaust Press. control valve high input
P0340 cam position sensor circuit malfunction
P0470 exhaust back press. sensor circuit malfunction
Now i can read what these things say but don't understand what they mean.
Do i clear the codes and see if they come back?
Thank you
As for the other codes. You will almost always see the 0603 KAM error with any truck that has a chip/tuner, or has had the batteries disconnected recently.
The EBP codes are not critical, but you can clean out the tube to help things. Here's a link with instructions on how to do that Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Do you know how to change the CPS or VSS if that becomes necessary?
Welcome to FTE.
i'm gonna clear the codes and drive it and see what codes come back but can't hurt to change those sensors either way.
I am moving at the beginning of may from Montreal Quebec to Vancouver British Columbia 2700 miles or so and want to make sure the truck is tip top for the trek.
I don't have a link on the VSS, but it's even more simple. The VSS is located on top of the rear differential. Find the wires going on top of the rear diff, and you'll find the sensor. Clean any dirt from the surrounding area. Unplug the wire connector, remove the one bolt holding it in, and pull the VSS out. The VSS from the auto parts stores work fine, so no worries about picking one up from there.
Spend some time reading through the threads here and you'll know more about these trucks than you ever dreamed possible. And do be shy about jumping in on a thread and asking questions. We were all new once, but we're all here to learn.
" We are all students and teachers in the school of life" Thanks for your help .
