Rear brake adjustment
Old Mar 17, 2009 | 05:25 PM
milesg's Avatar
milesg
I just replaced the parking brake pedal and now the brake shoes in the drums (the truck has disc brakes in back) are too tight. To loosen the pads, do I turn the star wheel down or up? I have tried several clicks both ways without effect. Thanks.
Miles G
Old Mar 17, 2009 | 06:07 PM
just another truck's Avatar
just another truck
First take the drums off, pull the little adjuster rod out, turn the thumb wheel from top to bottom, put your drum on, put your wheel on, jack it up. Start spinning the wheel, You dont really want it spinning real free, you kind of want the shoe just touching the drum, hard to explain for me at a key board, but for me, i would try to get the wheel spinning, and see how it does, when I was done adjusting, I would want the wheel to spin maybe 1 1/2 turn. To tighten, you want to take the spoon and pry towards the bottom.
Now get off the 1999-2003 7.3 forum.......
JK. Good luck!!
