Door open light always on...
Old Mar 17, 2009 | 01:57 PM
Ford554's Avatar
Ford554
which is keeping all the interior lights on & the running board lights. I obviously checked all the doors/gate & they are closed. I pulled the instrument cluster fuse to shut it off when I'm not driving. Is there a common problem that anyone knows of? I can't find anything wrong with any of the doors
Old Mar 17, 2009 | 02:23 PM
Monsta's Avatar
Monsta
Sit. Stay.
Very common.
First thing to try is to spray down all your door latches (liberally) with WD-40 or similar. Open and close the doors a few times to work the stuff in.
The latches gunk up and prevent the switch for the interior lights from being activated. Don't know which one it is but the best thing to do is to just do them all.
Old Mar 17, 2009 | 02:55 PM
Ford554's Avatar
Ford554
Monsta,
If my *** ever ends up anywhere near you in Hawaii I owe you a BIG drink! I soaked all the door latches & we're all good now!!!
Thanks so much,
Justin
Old Mar 17, 2009 | 09:19 PM
RACERX7775's Avatar
RACERX7775
i did it too but my light stays on still. i pulled the relay instead of the fuse. any easy way to determine which door it is?
Old Mar 17, 2009 | 10:40 PM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by Ford554
Monsta,
Thanks so much,
Justin
Glad it worked Justin! Thanks for the kudos and the offer. Let me know when you head over.
Old Mar 17, 2009 | 10:42 PM
Monsta's Avatar
Monsta
Sit. Stay.
The only way is to get them to all go off (Will they go off once you lock the doors?) and then open & close each door, one at a time and wait to see which one doesn't turn off...I guess.
Old Mar 17, 2009 | 11:07 PM
moto4's Avatar
moto4
I used silicone spray instead of WD-40, and it worked great! I would suggest using an air gun and blowing out the locks and then spraying them LIBERALLY with silicone. Be sure to spray all parts of the rear hatch latches.
Old Mar 18, 2009 | 02:53 AM
officer131's Avatar
officer131
I used WD-40 and worked fine.
Old Apr 11, 2009 | 02:13 PM
Rickx's Avatar
Rickx
Mine would not go off when I locked the doors. I just waited for the time out (about 40 minutes) and opened a door to see if the lights came on. It was the lift gate. To remedy I sprayed with wd40 but the problem returned. I removed the trim and then the switches and reprayed and wrapped them with electrical tape to keep thedust out. This fix has lasted over two years.
Old Apr 12, 2009 | 11:42 AM
Daviddc114's Avatar
Daviddc114
i believe when the truck is running everytime you open a door even if one is opened already the cluster beeps, open each door and the one that does not beep is probly the one that has a bad switch
Old Apr 12, 2009 | 05:36 PM
RACERX7775's Avatar
RACERX7775
David, no workie... I tried it in park, drive, and while driving. I do know that the lights all turn off when I hit a certain speed, 15 i think... As soon as I start the truck, it has the one beep and thats it. idk, I just pulled the relay back out...........
Old Apr 12, 2009 | 05:53 PM
Rickx's Avatar
Rickx
If you sneak up on your X while all lights are off and open a door. If the lights DON'T come on you've found your culprit. I did this over a couple of days and it was my liftgate.
Old Apr 12, 2009 | 06:13 PM
RACERX7775's Avatar
RACERX7775
ok, that sounds better. i just tried to mess with the tailgate actuator.. BROKE IT!!!! well, at least I'll get a new one for the tailgate. who knows, maybe that will be the bad one anyway.
Old Apr 12, 2009 | 08:53 PM
RACERX7775's Avatar
RACERX7775
Rick, thanks. It worked. I found out that its the drivers door actuator. FINALLY.. I ordered the actuator. 1 left, 1 right, 1 tailgate. total $101.
Old Apr 15, 2009 | 09:26 PM
RACERX7775's Avatar
RACERX7775
One last question.... I ordered the lock actuators. Is this the wrong part? Is the latch assembly what controls the door open light to stay on or is it the lock actuator assemblies? Did I screw up and order the wrong thing? Ugh, I hate this.........
