Airbag warning light
Old Mar 17, 2009 | 04:57 AM
Shovelhead 93's Avatar
Shovelhead 93
Question Airbag warning light
My 05 has the airbag light lit up it is the one with the guy sitting in the seat with seatbelt on and the airbag inflated in front of him what would cause this to light up?
Old Mar 17, 2009 | 04:56 PM
wildcard30's Avatar
wildcard30
Does it flash a code when you turn on the ignition?
Old Mar 18, 2009 | 08:01 AM
Shovelhead 93
No it just comes on it doesnt always do it and it is off now stayed on for a few days.
Old Mar 19, 2009 | 12:00 AM
ford2go's Avatar
ford2go
On a lot of vehicles that seems to mean that the airbag isn't working.
Generally related to the'clockspring' in the steering wheel. More than one make/model has had recalls or TSBs describing the situation.
You might want to check for Ford TSBs relating to this symptom. Some nice person on this site may be able to help you with that.
Old Mar 20, 2009 | 05:47 AM
shorebird's Avatar
shorebird
At the top of the page there is a gray menu bar with a section headed "RECALLs/TSBs". I'm almost certain that the light will flash right after start-up to give a code when there is a problem in the system. It will then remain steady on after the sequence has flashed three times.
