E40D's are junk please help
Old Mar 17, 2009 | 01:51 AM
YTcustoms's Avatar
YTcustoms
i have a 94 turbo diesel and have tried two different transmissions and both do the same thing when i put it in reverse it will pop and grind what could this be, and also how hard would it be to change to a manual becides, pedals and drive shafts
Old Mar 17, 2009 | 07:36 AM
PLC7.3's Avatar
PLC7.3
2X4 or 4X4........ the reason I ask is do you have a transfer case. What does it do in forward gears.....
Old Mar 17, 2009 | 08:16 AM
Lazy K's Avatar
Lazy K
Cracked/broken flex plate? Defective trans mount or engine mount?
Old Mar 17, 2009 | 08:32 PM
Dave Sponaugle's Avatar
Dave Sponaugle
YTcustoms,
Welcome to FTE and the IDI diesel forum.
If two transmissions act the same way, it sounds like the problem may be something else.
