Rear Diff carnage...
Old Mar 16, 2009 | 09:41 PM
CSIPSD's Avatar
CSIPSD
You too can have this box of broken parts for the small sum of $2500
Old Mar 16, 2009 | 10:02 PM
bdrummonds's Avatar
bdrummonds
I almost hesitate to ask what you were doing when this happened.... But for "research" sake I will ask. racing? pulling? towing? all of the above over time?
Old Mar 16, 2009 | 10:06 PM
jtharvey's Avatar
jtharvey
Dang Joe! I want to know as well...what were you doing when this happened? Do you have a locker or tru trac of some sort?
Old Mar 16, 2009 | 10:32 PM
CSIPSD's Avatar
CSIPSD
Pulling 27,000 GVW up a 6-7% grade in the tow setting... Open diff up till now. I think that may have been part of the issue, too many one wheel peels hooking up over the years...
Put a new set of 4.30 gears and a true trac in it now... Dont know why I ever waited to do gears, like a whole new truck.
Old Mar 16, 2009 | 10:38 PM
Smokin''s Avatar
Smokin'
Smokin
Yeeek!
Looking at those pictures is like listening to fingernails on a chalkboard.
Old Mar 16, 2009 | 10:42 PM
robs01f250's Avatar
robs01f250
I have two words for that......THAT's HEARTBREAKING
Old Mar 16, 2009 | 11:18 PM
makomaker's Avatar
makomaker
Nice...ole boy a couple threads down wants to haul a D4 w/ a 3/4 ton SWB, show him these pics and the write-upon how to fix it.
Old Mar 16, 2009 | 11:25 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Is it just me or does some of that damage on that gear look old?
Old Mar 16, 2009 | 11:35 PM
CSIPSD's Avatar
CSIPSD
Dont know... Still covered in gear oil, really not sure what caused that in the first place other then a few one wheel peels over the years.
Old Mar 16, 2009 | 11:44 PM
whitetr's Avatar
whitetr
I'm with you Mike, a couple of those teeth look as if they have been broken for a while and finally completely let go.
Old Mar 17, 2009 | 12:44 AM
randomhero1172's Avatar
randomhero1172
Ouch! Well, better then the engine or trans ..... to me i guess
Old Mar 17, 2009 | 02:34 AM
rebelchevy02's Avatar
rebelchevy02
One wheel peels, are usually hardest on the spider gears, that the axle shafts slide into. Ive done my share of destroying spider gears. Usually in half ton or lighter driveline. Then once the spider gear splits into parts, they go though the gearset and do their damage. Not saying thats what happened to yours, but usually one wheel peels, lead to spider gear damage. However, in retrospect to that, a truck that makes as much torque as you do, with a sudden "hook up" could be what caused the initial break on that part of the gear set. Then when you were workign them up the hill, it was enough torque applied, pulling your weight, to finally make an event.
Old Mar 17, 2009 | 06:50 AM
Kwikkordead's Avatar
Kwikkordead
Nice, LOL.
Old Mar 17, 2009 | 06:57 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Nice pics, i've fixed similar. I was going to suggest time for new gears but you already got that covered. Truck is alot quicker now isnt it?
Old Mar 17, 2009 | 07:46 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Look at the positive side you got a true trac out of the deal.
