Oil Leak
Old Mar 16, 2009 | 09:38 PM
ghig1967's Avatar
ghig1967
Oil Leak
I've put 2 pics in an album on my profile (since I can't seem to post pics.. anyone know why?) The one pic is not very good quality, but basically the whole back of my drivers side valve pan cover is coated in oil. Are these both something that the CCV mod will fix or is there something more to these leaks? Thx in advance everyone..
Old Mar 16, 2009 | 09:53 PM
guzzle92's Avatar
guzzle92
From what I can see in the pics, it looks like you CAC boots are pretty oil saturated. Besides the CCV mod, (RiffRaff Performance is coming out with a CCV kit that includes CCV doghouse o-rings) that will keep them from getting that bad. I would also recommend getting new spyder boots from Dieselsite.com that will hold up much better than the factory boots.
Old Mar 17, 2009 | 08:44 AM
ghig1967's Avatar
ghig1967
OK, thanks. I want to start cleaning things up under the hood & those 2 items are the worst...
Old Mar 17, 2009 | 09:29 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Here you go again Gregg. I do think doing the CCV mod will clean all this up. You may have another leak some where but it will be hard to find, untill you clean the valley up.
Old Mar 17, 2009 | 09:31 AM
ghig1967's Avatar
ghig1967
Thanks.. Anyone have any tips on a good way to get started cleaning up under the hood? degreasing, etc??
Old Mar 17, 2009 | 09:39 AM
miller_feed
I use Simple Green, I spray it straight from a gallon jug with a washdown gun, (air gun). Then I get a paint brush and help the bad spots out. Then using a water hose, I spray the engine down with water. It might take a few times to get it like you like it. But it works for me.
The Miller Lite is optional. lol.
<CENTER itxtvisited="1"></CENTER>
Old Mar 17, 2009 | 09:54 AM
Ponyboychris's Avatar
Ponyboychris
Are you sure it's "optional"? HA!
Simple green for me to. It works wonders.
Old Mar 17, 2009 | 10:04 AM
miller_feed
Not for me Chris. I don't spray the green stuff without my hugger (full).
Old Mar 17, 2009 | 10:57 AM
Ponyboychris
Good man!
I also found that the tire spray stuff shines up the stuff real well under the hood. I use the Simple Green first then the tire stuff last. Once you get the first round of gunk off the boots and engine, it's easier to maintain the cleanliness. Yes, do the CCV mod.
Old Mar 17, 2009 | 11:17 AM
miller_feed
Good man!
Darn Chris, you are telling my secrets. lol. I use the tire spray stuff to.
Old Mar 17, 2009 | 11:33 AM
Ponyboychris
Learning from the best.
Old Mar 17, 2009 | 03:58 PM
ghig1967's Avatar
ghig1967
Thanks guys... Other than the obvious of covering the filter.. anything else i should worry about getting wet?
Old Mar 17, 2009 | 04:30 PM
miller_feed
Some people cover the power steering cap because of the small hole on the top. I take the intake hose with the filter attached to it off, and cover the hole on the rest of the intake. Don't spray water directly on the alt or ac. Other then that I get busy, way down in the valley and around the turbo. Have fun.
Old Mar 17, 2009 | 07:42 PM
Ponyboychris
I cover the alt and the power steering units. And use a low pressure spray nozzle on the garden hose. Not one of those high pressure units. No need to force water into any crevices that don't need it.
Old Mar 17, 2009 | 07:49 PM
ghig1967's Avatar
ghig1967
That was going to be my next question. I'll just leave the pressure washer in the garage.. thanks guys !!
