Electrolytic Rust Removal
Old Mar 16, 2009 | 05:41 PM
rods4life's Avatar
rods4life
Has anyone done this? I just did this to some of my parts and it worked out great! Now I want to paint and prime them. I wiped them down but it does not seem like it got everything off. I am thinking of letting them dry, and taking a light hand held wire brush and brushing them. Then I would wipethem down and prime with rusty metal primer. Does this sound good? any ideas?
Old Mar 16, 2009 | 06:39 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Try lacquer thinner or acetone wipe-down; if it makes the cloth dirty red, you still have stuff on there. Soap and water followed by something like thinner or acetone to remove any greasy prints.
Old Mar 16, 2009 | 08:56 PM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
I spryed mine down with brake cleaner, let it air dry for a few and shot it with zero-rust paint. Just my .02!!!!!!!!!!
Old Mar 16, 2009 | 09:37 PM
TxF100's Avatar
TxF100
What did you use for power? do you have any pictures of your setup?
Old Mar 16, 2009 | 10:15 PM
thewizard182's Avatar
thewizard182
I've done it using a battery charger, a Rubbermaid container, and some steel flat bar as the anode. I use a piece of wood laid across the rubbermaid, a piece of round steel small enough to bend to support the peices, and jumper cables to make sure it all has good electrical contact. My anodes surround the container and are wired together with bolts and nuts through holes in the anodes.
It works great.
Your part will usually be a black color when you are done converting all the rust. I use acetone or some other solvent, then prime and paint.
For really bad parts i will let it sit in there awhile, then wire brush, then in again.
Old Mar 16, 2009 | 10:54 PM
CharlieLed's Avatar
CharlieLed
I did a fairly complete writeup on the process, it is in the tech archives on the HAMB.
TOOLS, Rust Removal, the easy way... - THE H.A.M.B.
I'll answer any questions you may have here...
Old Mar 17, 2009 | 09:47 AM
dave boley's Avatar
dave boley
I have done quite a bit of this with heavy machine parts. I started when I was rebuilding an old South Bend 15" X 60" lathe. I had some pretty big parts so I used a heavy duty 55 gal. plastic drum with a five post anode ring and a perforated inner plastic liner to keep the work piece from touching the anodes. I used a DC welder for the power supply and pulled about thirty amps. I found the cheapest place to get the bi-carb of soda was the local tractor supply place. I have some pics stored on one of my computers. If I can find them I'll post them.
There was always a black like film on the stuff when I was done so I used my pressure washer to clean that off first and then acetone. If you are painting the finish item it is really a good idea to get on it right away because the stuff will flash rust while youn are looking at it. One other thing, at least to a point it seemed that the muckier the solution got the better the thing worked.
I would kike to find an old fiberglass bathtub for bigger parts. I have even heard of people digging a pit and lining it with heavy plastic sheeting to do extremely large parts like car bodies.
Later Man...
HD74's Avatar
HD74
Nice tech artical. Filed for future referance.
Old Mar 17, 2009 | 03:49 PM
angus's Avatar
angus
I wire brush and wash the black stuff off... then soak in citric acid solution (if it'll fit in the bucket), and finally treat it with metal prep (like Ospho) or Naval Jelly.
For power, I tried a 3.3V 3A wall wart, but I'd only get a couple hundred milliamps of current. So, I've gone to a variable supply of around 10 volts, and sometimes it's pulled more than 1 amp. This is for items no bigger than a dual headlight door.
The sacrificial steel is a chunk of computer case with the paint sanded off.
I also picked up a 15 liter bucket of molasses at the feed store for $18; haven't tried that yet because we've still been getting frosts and snow here on sunny Vancouver Island. (The electrolysis bucket iced over, but didn't freeze solid.)
Old Mar 24, 2009 | 07:26 PM
pcmenten's Avatar
pcmenten
I've uses a battery charger, a length of rebar, Red Devil lye, washing soda and a plastic barrel. It works ok. Wash the parts with a pressure washer and spray the bare metal with Phosphoric Acid metal etch.
Old Mar 25, 2009 | 08:49 PM
rods4life's Avatar
rods4life
After doing this I was going to was the parts in mineral spirits and them prime them. Would that be OK or would the spirits be too oily?
Old Mar 25, 2009 | 09:43 PM
CharlieLed's Avatar
CharlieLed
Just like angus said, light wire brushing and a good wash does the trick. There's nothing on the parts that mineral spirits will cut. I sometimes use carb cleaner spray if anything just because it's so convenient and dries so quickly...also with the spray it will blow any debris out of the tight spots.
Old Mar 25, 2009 | 10:34 PM
pcmenten's Avatar
pcmenten
Phosphoric Acid is called 'Metal Etch and Prep'. I use a garden sprayer, dilute it with some water and spray the bare metal. The Phosphorus reacts with Magnetite and Ferric Oxide and forms a Iron Phosphate compound. Use primer after cleaning with Phosphoric Acid, then paint.
Old Mar 26, 2009 | 01:27 PM
53 Effie's Avatar
53 Effie
I found that using steel for the anode causes the steel to rust very fast as it is sacrificed in the chemical process. One day of being in the sodium carbonate solution with current passing through it will make the anode look like it had been laying outside on the ground for about 10 years. I use a piece of 3/4 inch stainless tubing. Lasts much much longer and requires being cleaned far less often. A dirty anode will limit the current, slowing down the process. Make sure the battery charger clip connected to the anode doesn't fall into the solution or it will also become a sacrifical anode.
I noticed one person on HAMB say he uses sodium bicarbonate or baking soda. I used sodium carbonate or washing soda. It works faster because the pH is higher.
Rick
Old Mar 26, 2009 | 02:38 PM
TxF100's Avatar
TxF100
Rick do you have a link or a brand of washing soda?
Rick
