2000 expo weird starting problems
Old Mar 16, 2009 | 05:35 PM
exporangerman's Avatar
exporangerman
I have a 2000 expedition 5.4 4x4. I went out to start my truck and it did not fully start, it died. I tried to start it again and it died. The third time while cranking it I gave it some gas and it started but a puff of white smoke came out of tail pipe. My truck stayed running and was idleing fine but there was a rich exhaust smell coming from the tail pipe. I drove my truck to work and started it back up a few hours later and it was fine. Then it sat overnight and it would not start until the third try. There was no smoke this time, but the same smell. A few hours later it did the same thing again. Two to three hours after that it started up fine. Runs good while driving and idling. Any ideas? Thanks for your help!
Old Mar 16, 2009 | 08:29 PM
alloro's Avatar
alloro
Sounds like your valve seals could be shot and allowing an excess amount of oil to leak down into the cylinders. When the truck sits for a long time (like overnight) more oil is allowed to build up than when it sits for a short while.
Old Mar 16, 2009 | 08:44 PM
exporangerman
If that is happening, then my oil level should slowly be going down, right?
Old Mar 16, 2009 | 08:45 PM
alloro's Avatar
alloro
Yes, but not as fast as you might think. It does not take much oil in a cylinder to foul a spark plug.
Old Mar 16, 2009 | 08:56 PM
exporangerman
My truck has 106,500 miles on it. Two hours ago I just replaced all 8 plugs, boots, and springs on the coil packs. None of the plugs were wet or oily and they had normal heat wear on them.
