Leak @ trans/driveshaft
Old Mar 16, 2009 | 04:21 PM
guitarpicr's Avatar
guitarpicr
Hey all - I have a small leak at trans seal where driveshaft exits. Is this an immediate concern? Not even dripping, just more damp around the seal. I'm kinda freaky about leaks, is this a major repair? Thanks,
Old Mar 16, 2009 | 05:12 PM
big poppa's Avatar
big poppa
Here's a bump for you Bill, subscribing...
Old Mar 16, 2009 | 06:41 PM
61 uni's Avatar
61 uni
There should be a seal there. Local tranny shop put one in my s10 for $40. Probably cost 100 in this truck, everything for these trucks are $$$$$$$$$$$$
Old Mar 16, 2009 | 06:44 PM
guitarpicr's Avatar
guitarpicr
That,s not too bad. I was afraid it might be something more expensive. Is this called the pinion seal?
Old Mar 16, 2009 | 06:47 PM
61 uni's Avatar
61 uni
Pinion seal is on the rear end. Tranny output shaft seal???? Not shure of the correct term. Any tranny shop could do it in bout 30 min. I wouldn't try it yourself. I put 2 in my s10 and they leaked. Tranny shop job has been good a couple of years now.
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
No Bill, the pinion seal is on the rear and front end, where the driveshaft goes in. I wouldn't worry about it if it is not leaking. Only a little wet, I would leave it alone.
Old Mar 16, 2009 | 08:41 PM
rebelchevy02's Avatar
rebelchevy02
IMO its a pretty simple seal to replace, and is similar to replacing a pinion seal. But like said above, its an output shaft seal. Remove the driveshaft, and then the yoke, then there should be enough of a lip on the outside, to get a small punch at it, and tap it out, and go around the ring, while tapping, dont just try and do it all from one side. Have a catch pan under it so you can catch some ATF, then whipe the area clean with a lint free rag, (so as to not leave any residue) and then tap the new seal into place (going around the ring again, this is a little tricky to start) and then install the yoke, and then the driveshaft.
The only part you may not have to do, and I dont know this because Ive never been under a 2wd super duty, is the driveshaft may have a slip yoke instead of a fixed yoke, like the 4wd trucks have. If thats the case you just remove the driveshaft, and then the seal, since the yoke is attatched to the shaft.
Jay_ford476
1997 - 2003 F150
May 25, 2013 07:56 PM
MDSuperDuty
Nov 14, 2011 12:14 PM
BigBlue92
Nov 6, 2011 06:28 PM
low00jetta
Crossovers
16
May 8, 2009 01:03 PM
95f150
May 15, 2005 08:55 AM
