Front Transfer Case - 1992 F-250 4x4
Hello all,
First of all I should tell you I am new to this forum. Just bought a 1992 F-250 4x4 and will be doing a lot of maintenance to it, since it looks like it has been neglected for a very long time.
I have 2 questions for today:
So I was underneath it last night giving it the first oil change it has had in a long time and was just shining my trouble light around under there. I noticed that the shaft going into the front transfer case is leaking. So - how hard is it to replace this seal? I can do most things myself - I have done brakes, front axles on smaller cars, some pretty serious work on engines, but I have not worked on 4x4s before. Is this likely just a seal? Would I need special tools? Is there a procedure online I could see?
Also, I get grinding when downshifting to 2nd as I coast to a stop. Transmission is a ZF. Would this be a synchros issue or should I not be downshifting like I do on my car?
Thanks in advance
Eric
Thanks in advance
Eric
minnesotafisherman
65
06-02-2015 10:13 PM
l67cooled
12-29-2009 04:53 PM
