Sponsored by: Real Truck
squealing driver's side Hub
Old Mar 16, 2009 | 10:55 AM
loudford's Avatar
loudford
I still have the ESOF and it's working but when I engage the hubs I get a squealling noise from the Drivers side Hub. This started after a really cold spell and I have only used it very sparingly since. I'm thinking needle bearing need's to be serviced but if that was the case wouldn't the squealling be 24/7 and not only just when the hubs are engaged? The squealling slowly subsides as I drive along a few miles. I have 62K on the truck now and it's mostly stock i.e. tires. I didn't want to pull the locking Hubs until after the winter is done just in case they are garbage and need to order new...
Thanks for any advice.
Lou
Old Mar 16, 2009 | 02:55 PM
BostonX73's Avatar
BostonX73
Mine did this a few times this winter when coming out of 4WD. Would stop after a minute or so. I checked all the air lines and hosed the hub down with WD40 and the last few times I needed 4WD it hasn't happened.
Old Mar 17, 2009 | 07:09 AM
loudford's Avatar
loudford
Did you pull off the Hub? I'll try and clean/regrease it.
Thanks,
Old Mar 17, 2009 | 08:05 AM
BostonX73's Avatar
BostonX73
that was going to be my next step if the quick spray didn't take care of it. I probably will try to tear into it this spring though and check it all out. truck has 100K miles on it now, so I'm sure it could use it.
Old Mar 17, 2009 | 08:19 AM
loudford's Avatar
loudford
great thanks, I'll try the spray and if it quiets down then I'll know it's just the locking hub that needs cleaning/regreasing. The thing is if you pull the hub I guess you have to replace the o-ring or the vacuum may leak so you may want to pick up a couple before hand.
Thanks again.
Lou
Super1ford
Jul 19, 2013 06:21 PM
86f250XLT-4x4
Dec 18, 2011 02:55 PM
lrgche
Mar 30, 2011 08:22 PM
JRFX4
2004 - 2008 F150
Dec 18, 2004 09:52 AM
