Big problem
Old Mar 15, 2009 | 11:08 PM
papa tapout's Avatar
papa tapout
Big problem
my 95 ford f-350 will start and run fine but when i kill it after running i have to wait untill the engine is cooled down completly for it to start again...does anybody know whats wrong with it?
Old Mar 15, 2009 | 11:29 PM
flamebuster's Avatar
flamebuster
what is it doing or not doing? I mean does it just click the selonoid, or turn over and not fire? need a little more information...
Old Mar 15, 2009 | 11:46 PM
BlueMule's Avatar
BlueMule
Sounds like IPR o-rings are leaking. With a cold engine the oil is thick enough to build enough oil pressure to fire the injectors but once it heats up it thins out and leaks past them enough to keep it from starting. Once the engine is running the hpop has enough pressure to keep it running even with the bad o-rings.
Old Mar 15, 2009 | 11:59 PM
matt71's Avatar
matt71
I had this same problem about a month ago. Blue Mule is right, IPR o-rings are bad. Fairly cheap and not to bad of a job. Took me about two hours taking my time, I pulled my fuel bowl, everything is alot easier to get at with it out of the way JMO.....
Old Mar 16, 2009 | 07:19 AM
Cuda_jim's Avatar
Cuda_jim
Welcome to FTE. I agree with these guys above. You need IPR o'rings.
Here's a link to more info:
New Page 0
Old Mar 16, 2009 | 04:02 PM
papa tapout
it turns over it just wont fire.
Old Mar 16, 2009 | 04:04 PM
papa tapout
how many o-rings are in the IPR or will i have to buy a set and replase all the o-rings in the fuel injector system? Is it a dealer item only?
Old Mar 16, 2009 | 04:06 PM
papa tapout
how many o-rings are in the IPR or am i going to have to buy a set and replace all the o-rings in the fuel injector system? is it a dealer item only?
Old Mar 16, 2009 | 05:44 PM
Cuda_jim's Avatar
Cuda_jim
Dealer item and International Harvester only as far as I know.
Maybe othere will chime in with more vendors.
IPR O-Ring Kit (for when IPR valve replacement is not required)
* (Ford) F6TZ-9C977-AN (F6TZ-9C977-AA?)
* (International) 1825806C92 (1825806C91?)
Action4478's Avatar
Action4478
Look here ...
ipr o-ring kit F6TZ-9C977-AN or1825806C92 pictures from hobbies & interests photos on webshots
