4wd not engaging...need hub info
Old Mar 15, 2009 | 09:21 PM
lowharley's Avatar
lowharley
Lights are on, front driveshaft is turning, all fuses are good, appears that hubs are not engaging. How do these hubs work on a 01 f350, automatic vs locked, or any other ideas.
Thanks in adavance!
Old Mar 15, 2009 | 09:25 PM
fxstbchopper's Avatar
fxstbchopper
The auto hubs work off vacuum. Does your heat default to defrost no matter what you have it set to?
Old Mar 15, 2009 | 09:28 PM
Steve_250's Avatar
Steve_250
Here ya go, in an effort to not repeat the same thread over again...
Check this thread out, should be an easy fix!
https://www.ford-trucks.com/forums/8...-problems.html
