390 FE question?
Old Mar 15, 2009 | 07:22 PM
rebelman108's Avatar
rebelman108
390 FE question?
Will 427 high riser heads fit a 390 if I bore the 390 .060 over or put smaller valves in the HR heads?
any input is appreciated
Old Mar 15, 2009 | 07:43 PM
Bear 45/70's Avatar
Bear 45/70
What would be the point? You would ruin some great heads for what? Oh and even Medium Riser heads would work on a 390.
Old Mar 15, 2009 | 11:50 PM
85e150's Avatar
85e150
Don't ruin valuable heads--smaller valves in HR heads?
Don't bore your 390 .060 over without a sonic check. Even then, only bore what you need to clean it up. Thin cylinder walls are not your friend.
Old Mar 19, 2009 | 12:11 PM
MeanGene427's Avatar
MeanGene427
I'm not sure what you'd want to accomplish by that- a 390 isn't really big enough to support those kind of heads unless you really wind it up, bottom end would be pretty lame. Putting smaller valves in would be pretty expensive, and again, what's to be gained? JMHO, but you'd be much better off going with an E-bock 390-428 head w/ standard LR valve sizes, and Barry R's slightly modified sets are a pretty good deal.
BTW, most any head with 2.19/1.73 or bigger valves are NOT friendly with the 390 bore size, including the MR. Most of the big-valve heads also have a wider guide spacing, putting the outside edges of the valves even further out. I have a set of late low-riser "big H" heads, which have the standard guide spacing, but with 2.19/1.75 valves, and there's only about .023 between the valves- pretty tight, which is why the big-valve heads have the guides pushed further apart- and were designed to fit the 427 bore size
