460 Engine Rebuild
Old Mar 27, 2009 | 06:45 PM
MUSKRATT2's Avatar
MUSKRATT2
By the way what do's the Summit muffler sound like? Do's anybody know?
Old Mar 27, 2009 | 08:13 PM
385seriesHemi's Avatar
385seriesHemi
Originally Posted by doug1222556
Yes, they are turbocharged, but they are less than 1/2 the engine of a V-8 460, but your point is well taken.
The links that I listed go into way more detail than I care to here, especially the exhaust theory link, which covers the real culprit mistakenly referred to as "backpressure" ( which does not exist), when it talks about waves. You will also notice that it says bigger is better is absolutely wrong, but then see what size pipes are recommended.
What I really liked about that article is the reference to the exhaust system as being a 5TH stroke on a 4 stroke motor.
I'm more of a small-block stroker guy, but when I searched 460 headers at Summit, every one I looked at had 3" collectors, including the ones with only 1 5/8" primaries, yet another clue that 3" pipes are they way to go.
I was basing my original recommendation on the fact that in my research, 2 3/4" pipes are none too small, and 3" would be an option on the slightly less than 400 ci. 351W stroker I'm building.
Interesting, I am aware of the Positive and Negative pressure waves, but, haven't read anything yet to acknowledge they are in relation to if not one of them is the "backpressure" occurrence. Since I am limited with internet, could you PM me that entire link Doug?? if thats no trouble for you.
Old Mar 27, 2009 | 08:28 PM
385seriesHemi
Originally Posted by MUSKRATT2
Ok guys, I've done a search & I can only find 2 exhaust for my truck. One is from Summit which is a 3" exhaust & the part number SUM-684012, I don't know what type muffler this is, but would it really matter? The other is a Flowmaster 3" exhaust for an 87 to I believe 96 , which my truck is an 85 ( I can't remember the exact ending year) with a 70 series muffler. Which one would you guy's chose? The Summit is a whole lot cheaper. I can't find anything else or do you guys know of anything else out there? Wouldn't the Flowmaster exhaust wouk on my truck?
Flowmasters will work, but like Doug mentions, they are overrated and a little spendy for what they don't do. The Flowmaster mufflers are built for sound and not so much flow capability, which is pretty much contridicting its name huh? They should be named Soundmasters I think. I hear people talking alot on Borla mufflers though. If you go cheap like glasspack mufflers, Cherries or Thrush. I would pick Thrush because the tube inside Thrush's glasspacks look to be drilled or cut with a machine with no uneven surface. Cherry bomb's inner tuber has press-punched holes. Which causes a restriction from producing turbulence from uneven surface of that inside tube. Its all about that wallet you have boss.
Old Mar 27, 2009 | 11:15 PM
doug1222556's Avatar
doug1222556
Yeah, I don't know what happened with those links-WEIRD: I'm going to try and paste them here again:MagnaFlow Performance Exhaust. and :Theory. And I'll try to PM you a link as well. When I click on these links they take me tyo the right sites, but not with the other post, and I don't understand why they aren't the complete htt: blah blah blah that they are when I paste them.
Old Mar 28, 2009 | 07:37 AM
385seriesHemi
Now they work. Thanks.
Old Apr 25, 2009 | 01:24 PM
Lngbeard's Avatar
Lngbeard
When I did my first 460 rebuild I found a huge weight savings by installing aluminum intake manifold and losing the stock cast iron. Headers in addition to scavenging offer a weight savings. Can you strip off the emissions? I had two smog pumps and brackets which also weigh a lot. With these changes I got better performance and better mileage. Hope this helps.
Old Apr 27, 2009 | 08:06 AM
MUSKRATT2's Avatar
MUSKRATT2
OK guy's I want to ask another question here. 385serieshemi kind of addressed this but I want a clarification as to what everybody thinks. If you were rebuilding your motor would you put the EGR valve back on it or not? I have the Ededlbrock #1406 carburetor on it now.
Old Apr 27, 2009 | 09:55 AM
kernel-panic's Avatar
kernel-panic
To answer your question about emissions, technically, any vehicle 1968 and later can't have it removed if it's going to be driven on the road according to Federal law. Now, if you convinced someone that the last year that the 460 was offered, it didn't have any of that on it and tell 'em the engine was swapped in from a newer vehicle... I do agree that an aluminum intake and (emissions-equipped) headers save a lot of weight and yield better mpg's and performance, though.
I'm not a fan of EGR valves, personally. Does it still have the stock cast iron intake manifold on it or an aftermarket aluminum one (that maybe doesn't have the EGR port[s])? I'm trying to figure out why V-engines don't have an EGR tube going to each side and meeting in the middle for a balanced EGR path. I mean, if they were that worried about emissions and using EGR to recycle unburned gases, you would think they would have designed them like that... at least the GM engines were somewhat setup like that in the 80s, IIRC... I remember having to repair EGR tubing on one a la redneck engineering. Just an off-hand thought.
Old Apr 27, 2009 | 12:59 PM
MUSKRATT2's Avatar
MUSKRATT2
Right now it has a cast iron intake. The reason I'm asking this question though is because I plan on replacing it with an aluminum intake during the rebuild & I'm wandering whether to get an EGR intake or NON EGR intake.
Old Apr 30, 2009 | 10:06 AM
385seriesHemi
Well you could buy an intake manifold with the EGR port already cast into it (that is if they have them). Just cover that up until you feel the need to or have to use an EGR.
wrangler2520
Dec 6, 2010 11:36 AM
Bobcat7
Aug 12, 2009 04:22 PM
Old Time RV'er
Modular V10 (6.8l)
Aug 12, 2009 01:19 PM
71fordkid
Offroad & 4x4
Jul 26, 2009 08:54 PM
blown88
Mar 31, 2009 11:13 PM
