I'm working on replacing the blower fan in me 2002 F150 and I have removed all of the mounting screws but I can not drop it down far enough to get it out of the housing. It hits the floor board. Is there a trick to this or is this just a part that you need to force out of the housing or pull back all of the carpet and padding?
Welcome to FTE 2002 F-150 Here is what it says in the service manual.
Blower Motor
Removal and Installation All Vehicles
1. Remove the RH lower instrument panel insulator. 2. If equipped, remove the dealer installed air filter and brackets. 3. Remove the passenger side scuff plate. 4. Remove the passenger side kick panel.
1 Position aside the weatherstrip.
2 Remove the passenger side kick panel. 5. Disconnect and detach the electrical connector. 6. Position back the carpet.
EATC Vehicles
7. Disconnect the aspirator tube and remove the screw. 8. Remove the aspirator tube extension.
1 Remove the screws.
2 Remove the aspirator tube extension.
All Vehicles
9. Disconnect the electrical connector. 10. Remove the screws and remove the blower motor. 11. Remove the wheel from the blower motor.
1 Remove the clip. 2 Remove the blower wheel. 12. To install, reverse the removal procedure.
RanchKingan02
Thanks for the information. It is a lot of help, I was thinking that this would be required. Just hoping that I was wrong.
What a pain in the A$$ to replace a simple bolt in item.
I know this is a old thread but I was hoping I could ask a question on this subject. So you don't need to pull the dash to service the blower motor and fan? My Dad has a 99 F150 screw and he called me tonight and said when he turns the blower fan on his whole dash shakes. He said it sounds like something is stuck in it. I told him I'd look at it but I was hoping I wouldn't have to pull the dash. Any ideas on this problem? Thanks for any help you can give.
I pulled back the carpeting & cut the padding clean. Put the fan & cage in, fitted the padding back,returned the carpeting to it's original place.This worked-after I struggled for hours tring to squeeze the motor back in with the padding preventing installation.
