Bronco II Ford Bronco II
Engine change out in 1991 Explorer
Old Mar 14, 2009 | 06:25 PM
MessengerII's Avatar
MessengerII
Got a good engine out of 1991 Explorer, Manual Transmission, and I would like to place it into a 1994 Explorer, which has the same engine, but is a automatic transmission. I would prefer not to change the transmissions, so what trouble do I look for? Thanks
Old Mar 16, 2009 | 06:59 AM
kernel-panic's Avatar
kernel-panic
Only things you'd need to do to the donor vehicle's engine is remove the clutch parts (pressure plate, friction disc), remove the flywheel, and then remove the flex plate off the exisiting engine in the '94 and install it on the 'new' engine. I forget if there is a spacer for the flex plate or not, but it should be fairly straight forward. Hope this helps.
Old Mar 16, 2009 | 07:12 AM
MessengerII
Thanks for the good info. It does help.
