Lug nut bolt issue!!! please help!!!
Old Mar 14, 2009 | 03:41 PM
dferg476's Avatar
dferg476
Hey!
I tried removing the driver's side front wheel today and was able to get 4 nuts off the bolts, but the last one was seized onto the screw and when I tried to remove it, it they would spin together and I couldn't get it to budge!!!
So, I can't get the wheel off but need to find some way to get behind there to remove the bolts and replace them. Anyone have any experience?????
Thanks!!!
Old Mar 14, 2009 | 04:42 PM
uncle.stosh's Avatar
uncle.stosh
Take the caliper off, the spindle nut cover and the nut and take the whole thing off as one unit if it's 2WD. If it's 4WD use the same principal but pull the hubs apart, the nuts and the the whole rotor and spindle as one.
You'll then have access to the back side of the stud. You can then either drill or burn the stud out.
Old Mar 14, 2009 | 05:00 PM
Sportruk's Avatar
Sportruk
You could try drilling it off. With a 1/8" drill bit, drill the top of the nut, the side facing you, tight to the side of the stud until you drill the full depth of the nut. You can do the other side as well.
Step up a couple sizes and open up the hole. Eventually, you will cut through and the nut should fall off.
Old Mar 14, 2009 | 06:20 PM
dferg476's Avatar
dferg476
What a pain in the a$$.......I knew it would not be an easy fix....
Thanks for the info though gents!!!!
Old Mar 14, 2009 | 06:48 PM
bfbiker's Avatar
bfbiker
Talking nuts
go get a nut cracker from a tool place and put it on it will crack the nut makes it rweal easl to do
Old Mar 15, 2009 | 11:43 AM
dferg476's Avatar
dferg476
Cool!!
Thanks for the tip!! Every day I find a new project with this.....project. Ha!
Great learning experience!!!
Thanks again!
Old Mar 15, 2009 | 01:58 PM
uncle.stosh
That's a FORD for you.
Stands for: Fix Or Repair Daily.
Old Mar 15, 2009 | 04:49 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Go at it with a 5/8ths inch bi-metal hole saw but remove the center drill bit first; it's not required for tis application . The hole saw will remove the lug nut from the stud. You'll still need to replace stud since it is spinning in the hub. I have used this trick in the past to remove a lugnut that was rounded off BAD and didn't even damage the threads. Good luck and report back!
Old Mar 15, 2009 | 05:36 PM
bob_351's Avatar
bob_351
i would try the nut splitter bfbiker suggested. i have used the one for smaller nuts and it works wonders, its so simple and i only paid about $5 for mine
Old Mar 15, 2009 | 05:49 PM
Towmanjbo's Avatar
Towmanjbo
That's a really cool Idea!
Thanks
Old Mar 15, 2009 | 06:24 PM
bob_351's Avatar
bob_351
the one problem i could see with this is that if the stud is spinning then it will just spin with the holesaw. I could also see it scratching up your wheels
Old Mar 15, 2009 | 06:44 PM
Bern_F150_4x4
I hope the studs not that loose, but I suppose anythings possible. I used this method with an aluminum wheel on a Lincoln Town Car (neighbors) and no, it did not damage the wheel (I'm not sure how it could??). The saw has an OD of 5/8" and an ID of 1/2". Take your time and go slow... BTW, there was no room for the nut cracker to be effective as the lug nut was recessed in the wheel. Ya gotta do what ya gotta do.
Old Mar 15, 2009 | 07:33 PM
uncle.stosh
That's a good idea about the hole saw. Never thought of that.
FWIW: I have also step drilled through the center of the stud to the depth of the nut. Once you get close to the stud diameter the nut will fall right off.
That was on an expensive aluminum wheel with a lost key for a locking lug though. You need to center punch the stud and go slow with really sharp bits.
PITA but it works.
Old Mar 15, 2009 | 11:40 PM
dferg476's Avatar
dferg476
Im gonna have to go with the nutcracker I think. The stud is spinning freely, meaning I'm prob gonna have to replace the hub too, since it will prob be stripped there as well.
I'm gonna try to mess with it tomorrow......
Old Mar 16, 2009 | 06:49 AM
lew52's Avatar
lew52
If you have a 44 Magnum.. if used right it will blow the lug clean off ...
