Another Question from a newbie
Old Mar 14, 2009 | 02:51 PM
ford 5ver's Avatar
ford 5ver
Hi again everyone, I have another question here. My truck is a 2000 F350 with a 7.3 diesel with 214,000 miles. I've only had the truck for a few weeks and driven it very little. Probably less than 50 miles. Today I took it out to run some erands and while sitting in a parking lot with it idling it shut off. I mean shut off quick (instant). It did crank right back up. A few miles later while at a red light idling it shut off again very abruptly and again it cranked right back up. At this point I'm getting somewhat nervous wondering if it was going to leave me stranded. I pull into another parking lot and shut it off to go inside a store. Came back out to leave and it cranked right up. Took off across the parking lot and it died again. My question is, does anyone have any clues as to what might be causing the engine to die with no warning. The engine runs great and sounds great. This just started today. It was raining today, could that have any bearing on this?
Thanks in advance,
Gary
Old Mar 14, 2009 | 02:53 PM
Adam0331's Avatar
Adam0331
Possibly a bad CPS. Does it just die? Does it sputter or anything then die?
Old Mar 14, 2009 | 03:06 PM
Bigcat350's Avatar
Bigcat350
Like Adam said maybe CPS. Since you have only had it a few weeks you may want to check/change the oil, fuel filter drain the water bowl. I am sure you will get more info soon. Congrats on the truck.
Old Mar 14, 2009 | 03:22 PM
ford 5ver's Avatar
ford 5ver
newbie queston
Adam it dies instantly. No sputtering or anything. Just as quick as if you turned the key off. The oil was just change but not the fuel filter. Is there some kind of sensor in the fuel filter that would cause this? Thanks for the quick replies guys.
Gary
Old Mar 14, 2009 | 03:34 PM
Nick 99's Avatar
Nick 99
Ford has a recall out to replace the camshaft position sensor (CPS).
Check to see if your has been replaced, as it will cause this condition.
Old Mar 14, 2009 | 03:36 PM
rob188's Avatar
rob188
i've replaced several on the 7.3L when i was working at ford, its not difficult but your dealer will do it free cause its a recall
Old Mar 14, 2009 | 03:45 PM
ford 5ver's Avatar
ford 5ver
newbie
Ok guys, maybe we are getting somewhere. When I bought the truck, the guy said he had replaced the CPS and even had an extra one in the glove box. He called it a crankshaft sensor but I assume he mean camshaft sensor. Is it located underneath the engine, somewhat toward the front? This is the location he refered to when telling me about this.
Thanks again guys,
Gary
Old Mar 14, 2009 | 03:47 PM
rob188's Avatar
rob188
Thanks again guys,
Gary
yeah its right beside the crankshaft pully, it inserts into the block
Old Mar 14, 2009 | 03:49 PM
4EXTRDR's Avatar
4EXTRDR
It sounds just like when my CPS croaked...shut off at lights and start right back up, wait till it starts missing on the highway at 65 mph (ugh!!). If you are gonna do it yourself (it's really simple) Get one from an International Dealer versus Autozone or one of those places if possible.
Old Mar 14, 2009 | 03:50 PM
rob188's Avatar
rob188
its not a hard job just in an awkward place
Old Mar 14, 2009 | 04:17 PM
ford 5ver's Avatar
ford 5ver
Thanks guys
Well, I think you've nailed it. Like I said, I have one in the glovebox. Its actually kinda funny because on the way home my wife ask me if it could be that sensor the guy we bought the truck from was telling us about. Of course I said, no hon!!! Thanks again,
Gary
Old Mar 14, 2009 | 04:26 PM
Adam0331's Avatar
Adam0331
My Dad's acted the same way, then it died totally. It was his CPS.
Old Mar 14, 2009 | 04:36 PM
rob188's Avatar
rob188
well replace the CPS and i hope that will fix it for ya gl
