Diesel gearheads
Old Mar 14, 2009 | 12:59 PM
starmilt's Avatar
starmilt
Diesel gearheads
Over the years I have seen compression releases glow plugs intake grids start and warmup on gas and then nothing at all for starting aids.
One of the easiest diesels to start was the old case engines with nothing what made these start so good that the others had to have aids and still not as easy to start.
Old Mar 14, 2009 | 01:41 PM
RCrawler's Avatar
RCrawler
Direct injection, lower compression and fuel timing differences?
Jason
Old Mar 14, 2009 | 03:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Engine configuration also has a bit to do with it.
Long stroke and smaller bore means ther compression heat is in the cylinder longer so it starts to warm up faster.
Given the way the old Cases would roll the black smoke under loads, the fueling rate also contributed.
Old Mar 14, 2009 | 06:24 PM
dyoung14's Avatar
dyoung14
more advanced timing maybe?
