Sponsored by: Innova
6 Disc Player Interchange
Old Mar 13, 2009 | 10:20 PM
dadlovesfords's Avatar
dadlovesfords
I have a factory cd player that has the 2 plug harness setup on the back. I purchased a Ford factory Pioneer 6 disc unit out of a 2003 Sport Trac that has the three plug harness setup. Is the third plug on the unit for a sub? Will this unit work with the two plug harness that is in my 2000 F150 truck with out using the third connection?
Thanks for any help ,
Larry
Old Mar 15, 2009 | 09:53 PM
ReAX's Avatar
ReAX
2000 Ford F Series Stereo Wiring
Constant 12V+ Light Green/Pink
Switched 12V+ Black/Purple
Ground Black/Green
Illumination Light Blue/Red
Amplifier Remote Blue
Left Front (+) Gray/Light Blue
Left Front (-) Tan/Yellow
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Left Rear (+) Orange/Light Green
Left Rear (-) Light Blue/White
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
2003 Ford Sport trac
12V lt green/purple +
GROUND black -
SWITCHED yellow/black +
ILLUMINATE red/black +
LF SPEAKER org/lt grn-lt blu/wh
RF SPEAKER wht/lt grn - grn/org
LR SPEAKER tan/yel - gry/lt blu
RR SPEAKER org/red - brn/pnk
The colors aren't matching up, but I don't have access to pinouts.
If you must use this one, I would buy two harness. One that plugs into your truck and one that plugs into the new radio. Then match the wire colors up and you should have everything working.
Old Mar 22, 2009 | 12:22 PM
dadlovesfords
Thanks for the suggestion. Is the first plug-in from the left on this stereo for the factory amp? I have the 2nd and 3rd plug-ins on my truck already.
Thanks ,
Larry
