steering box leak
Old Mar 13, 2009 | 01:40 PM
master_mechanic's Avatar
master_mechanic
steering box leak
I've got an 86 f250... i've got a power steering leak somewhere in the steering box... its not the seal right by the pitman arm.. where else could it leak? can it be fixed or just replaced??
Old Mar 13, 2009 | 04:51 PM
Franklin2's Avatar
Franklin2
Clean the steering box up, and then see if you can find the leak after running it without driving down the road, where the wind blows it all over the place.
Old Mar 13, 2009 | 05:02 PM
master_mechanic
i had it running in my driveway for a while but i could find anything leaking... its more noticable when it sits for a while
Old Mar 14, 2009 | 10:11 AM
Franklin2's Avatar
Franklin2
Make sure you are not overfilling the reservoir. The fluid really expands when it gets hot. Also look over the steel line coiled up in front of the crossmember. This loop is a sort of primitive oil cooler, and it likes to rust out and leak.
