Diagnostic testing help!?
Old Mar 13, 2009 | 12:04 AM
WillFargo's Avatar
WillFargo
Looking to buy a OBDII to USB cable to use with some free software i found online. However, i looked on ebay for the cables, but practically all of them say "AUDI" or "VW" next to them. My understanding was, that OBDII is a universal plug on models post 1996. Can i just buy a cable such as this
eBay Motors: USB OBD2 OBDII Vag Com KKL Interface Cable for Audi VW (item 140302955212 end time Mar-22-09 20:21:22 PDT)
and use programs such as PCMScan 2.4.8 Build 880 and Dyno-Scan OBD II USB Adapter Device 4.28.0.2700 ?
Thanks for your help!
And if you know of any better FREE software, that would be awesome too. Thanks everyone.
Old Mar 19, 2009 | 05:38 PM
aquanaut20's Avatar
aquanaut20
First question, do you have one of the listed autos or a ford product >1996?
2nd Q, what is your intention, scan codes or diagnose the OBDII sensors?
Old Mar 19, 2009 | 05:44 PM
WillFargo's Avatar
WillFargo
Yes i have a 96 explorer. i want to be able to check engine codes and get freeze frame data
Old Mar 20, 2009 | 04:15 AM
aquanaut20's Avatar
aquanaut20
There are many options available, but if all you need is a code reader with FF, something like this will suffice.
U581 CAN Trouble Code Reader OBDII/EOBDII Memo Scanner - (eBay.ca item 220373285297 end time 04-Apr-09 23:41:45 EDT)
If you wish to get more involved, at the sensor level (live data) then you would need a computer/laptop and ElmScan 5 USB - ScanTool.net
Note I have no affiliation with any of my suggestions, but I use similar units.
For more in depth testing you would need an extended code set and test by PID's ("Parameter IDs").
Most generic testers only pick up emission related codes
