can you identify engine windsor or (Romeo) by vin number
#31
it should bolt right up I'm not sure about the electronics though. Torque converters may be an issue I know that you cannot use a 5.4 torque converter with a 4.6 transmission. not sure about the windsor converter. just to be safe replace both if the converter will bolt up. Check with rockauto.com they have both engines listed and I compare parts all the time if they have the same part number your good to go.
#32
Hello one more question(I think) as i have stated i have a 97 f150 4.6 and by what i have found out its a 6 bolt. someone has a 8 bolt engine 4.6 same year out of a econ van (ford) and they have the fly wheel. How can i use this engine its a 8 bolt and i have a 6 bolt and dont have a lot of money! Thank you for your time in advance...
Andre'
Andre'
#33
I don't know how much trouble you would run into but there have been some posts on FTE that talk about various accessory drives either not mounting up or being mis-aligned. I strongly suggest that you stay with the original engine family. Apples with apples and oranges with oranges is usually the best way to have the fewest problems.
'97 Econoline code 6 = 4.6 V8
'97 F150 code W = 4.6 Romeo
'97 F150 code 6 = 4.6 Windsor
My manual does not state the plant that the Econoline engine was manufactured at, the code seems to indicate that it is a Windsor built engine.
#34
Hello may i have some more imput, this repair shop(legit) has a 8 bolt engine and has the flywheel, told me he made some calls and he was told he could do the engine swap with no problem. im getting a good price.......i have a 6 bolt flywheel 4.6 97 f150. can a 8 bolt 4.6 be use if we use the 8 bolt flywheel?
#35
I believe the answer I gave in the post earlier would caution you. I suggest that you verify with the mechanic/shop that ALL accessories would be correctly placed, mounted and aligned without additional cost to you.
#37
You really need to be certain regarding the accessories. You can get a flywheel from a salvage yard or transmission parts sales company or even AutoZone.
Here's one for a Navigator, new for $50.00 and if you order the wrong one you can exchange it.
Pioneer/Flywheel - Automatic Transmission
For your 2000 Lincoln Truck Navigator 4WD 5.4L SFI DOHC 8cyl
Price:$49.99
Part Number: FRA-438
AVAILABILITY:
STORE PICK UP
AVAILABLE
Normally stocked at your local store.
SHIP TO HOME
AVAILABLE
Ships within 2 business days.
ADD TO CART
Eligible for FREE 2-Day Shipping
learn more | sign in
Part Number:
FRA-438
Weight:
5.95 lbs
Warranty:
1 YR
Application:
Transmission model 4R70W
Shipping Information:
Overnight and Two Day shipping are not available for PO Box, APO/FPO/DPO or US Territory addresses.
Price:$49.99
AVAILABILITY:
STORE PICK UP
AVAILABLE
SHIP TO HOME
AVAILABLE
ADD TO CART
Part Number:
FRA-438
Weight:
5.95 lbs
Warranty:
1 YR
Application:
#38
on
The following users liked this post:
#39
I know this is an old thread, but this statement if frequently made and is incorrect. One cannot reliably know the engine from the VIN. My 8th digit VIN is a 6, which would lead one to believe a Windsor 4.6L, but in fact, I have a Romeo with 11 bolt valve covers.
Best way to know is the engine code often found on the driver's side valve cover. Or just count the valve cover bolts.
#40
#42
#43
Vehicle Identification Numbers (VIN codes)/Ford/VIN Codes - Wikibooks, open books for an open world, from this, someone replace the engine then
Just check that website. Then read the details of the description from O'Reily's. It states, VIN 6 . . . . Romeo plant . . . 6 bolt flywheel. This pretty much proves that at least some of the VIN 6, 4.6L's came from Romeo plant with 6 bolt flywheels, 11 bolt valve covers, and all the other specs of Romeo 4.6L
<!-- / message -->
<!-- controls -->
#44
I have a 2000 F150 it has the 4.6 Id like to get as much info as possible on it my VIN # is
1FTRX18W2YKA85490 i plan to replace the motor eventually so i want to know what motor is it specifically an what motors i can replace it with without having to modify anything. any information would be appreciated. thanks
#45
