Need Info????
Old Mar 12, 2009 | 03:58 PM
Thirdlegspecial's Avatar
Thirdlegspecial
Question Need Info????
Hello ford lov'n freaks! I am a new member to this show and wanting some advise. I have a 04 F150 want to lift it a little, but not with body lift and don't have money for suspension. I'm looking at rancho quick lift. Any taker on this?
Old Mar 12, 2009 | 04:59 PM
fordman19762003's Avatar
fordman19762003
Welcome to the site, there is a wealth of info on here. I don't know much about the Rancho lift, but myself and alot of other people on here have installed Auto Spring leveling kits and have had good results. Auto Spring has an eBay store and that is where most people buy them, just run a search for F150 leveling kits and they should pop up. I bought mine last June and I think it cost $69 at the time. They make a 1.5",2",2.5", and I think they started offering a 3" also. I do alot of towing/hauling so I went with the 1.5" kit so I still have a little bit of rake, but alot of guys use the 2" to totally level the truck, and if you go with the higher kits your front will probably sit a little higher than the rear, so you'd have to install one of auto springs 1.5" rear blocks or their add a leaf kits to level the truck.
Old Mar 12, 2009 | 06:49 PM
Thirdlegspecial
Thank for some info. I'm still wondering of camber wear. Do you need to get a alignment with the spacers?
Old Mar 13, 2009 | 12:26 AM
deisele75's Avatar
deisele75
Yes.......
