Quick tanny swap question
Old Mar 12, 2009 | 12:49 AM
summitx670's Avatar
summitx670
Exclamation Quick tanny swap question
will a e40d out of a 1992 ford f150 4x4 with a 5.0L fit in my 1994 f150 4x4 with a 5.8L? both are e40d's so i dont see why not. just checkin to make sure before go spend the money on the parts truck.
Old Mar 12, 2009 | 12:54 AM
motorhead81's Avatar
motorhead81
yep both are 4x4 and the same trans
Old Mar 12, 2009 | 01:19 AM
summitx670's Avatar
summitx670
wiring and everything will be the same too and not going to mess up my computer? i was told 92 and 93 can mix and 94- 96 and mix not sure if thats true.
Old Mar 12, 2009 | 01:44 AM
motorhead81
no any time it is the same trans use every thing from the truck you are putting it into except the trans it self on computer controlled tranys just like an engine swap you can use the same sensors from the old engine in some situations
