steering wheel replacement
Old Mar 11, 2009 | 02:18 PM
two-stick's Avatar
two-stick
Will a steering wheel from a 1987 F-250 / F-350 fit a 1986 F-250?
The 1987 wheel looks a bit smaller in diameter.
Would like to change out the skinny wheel for a wheel a fit fatter.
Easier on the hands on long trips. Tried a cover but wasn't comfortable with it.
Old Mar 14, 2009 | 11:30 PM
1 F150dude's Avatar
1 F150dude
The 80-91 models use the same aftermarket mount kit, which means the shaft is the same size. Also the collumn diameter of the 87 looks the same as the 86. So i dont see any problems doing the swap.
Old Mar 15, 2009 | 07:37 AM
uncle.stosh's Avatar
uncle.stosh
Look for an XLT wheel from an 80/86 or a wheel from a van. Same splines, same style but much thicker.
Old Mar 15, 2009 | 08:00 AM
rmalottwtes30's Avatar
rmalottwtes30
I was looking at steering wheels out of a 87 and a 85, they look the same to me. I may even try this swap.
Old Mar 15, 2009 | 04:11 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
I think I got my "thick" wheel out of an '87 Bronco XLT; much nicer wheel. It went in to my '85 with no problem and is destined for the '86.
Old Mar 23, 2009 | 08:31 AM
two-stick's Avatar
two-stick
Smile found a wheel
Thanks to all for the information.
Found a fat wheel from a 82-86 XLT Bronco in excellent condition.
rmalottwtes30, you might be interested in my blog in 'a new brownie thread'.
