Bizzare (cold) coolant leak
Old Mar 15, 2009 | 02:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Well what was your swap time?
I usually lay the new pump beside the truck, put each bolt in the correct hole as I remove it.
When the pump is off, I transfer the bolts from the new pump to the old one.
Then start with assembly.
Old Mar 15, 2009 | 02:38 PM
CheaperJeeper's Avatar
CheaperJeeper
Haven't put it back together yet, but to get it all part, cleaned up and ready to put back together was about 2-1/2 hours (taking my time)
That's a good method, I've done similar, but usually manage to drop or knock it over and scatter bolts everywhere. The beauty of the carboard box is that since I poke smaller holes than the bolt diameters and then force them into the holes, they don't fall out so easy if I butterfinger and drop it or end up kicking it over...
davido
Jul 16, 2013 04:19 PM
wipeoutwm
Modular V8 (4.6L, 5.4L)
Dec 16, 2011 11:58 PM
PaulwestSki
34
Sep 23, 2011 05:27 PM
b4hntn
1978 - 1996 Big Bronco
Jun 21, 2008 05:51 PM
jerseydevil
18
Jul 17, 2005 09:45 PM
