Ball Joints
Old Mar 10, 2009 | 05:05 PM
gt5-33's Avatar
gt5-33
Ball Joints
What is the best way to tell if your ball joints are in need of replacement? 2WD drive
Old Mar 10, 2009 | 05:09 PM
Sooper-Doodie's Avatar
Sooper-Doodie
Jack it up, put your hands on the wheel at 12 and 6 o'clock positions and try to move the wheel. If it moves, you have bad ball-joints.
If you put your hands on 9 and 3 o'clock and move the wheel, you can test the tie rod ends.
Old Mar 10, 2009 | 05:34 PM
gt5-33's Avatar
gt5-33
Thanks for the information. Tom
Old Mar 11, 2009 | 09:10 AM
manglass's Avatar
manglass
You might have someone look to verify that the play is in the ball joint and it's not just a loose wheel bearing. If it has over 100k, they are questionable.
Lou
Old May 14, 2010 | 08:59 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I think mine are well beyond questionable at almost 300K!!!
Btw, Advance Auto Parts is offering 15% off orders $100 or more with coupon code H115. I just saved almost $30 off the Moog Ball Joints I just ordered!
Old May 14, 2010 | 09:37 AM
jpcjguy's Avatar
jpcjguy
Ball joints are fun. NOT!
Don't forget to replace any necessary seals - I know the 4x4 there are 2 seals and an O-ring.
