shimming the FPR
Old Mar 10, 2009 | 10:03 AM
RRranch's Avatar
RRranch
shimming the FPR
What is the difference between shimming the Fuel pressure regulator and putting in the BB mod like I have been reading? Or is it two separate parts that get each mod?
My fuel pressure is borderline at 50 psi and I was going to go shim it up a bit but wanted to know the difference in the 2 mods first.
Old Mar 10, 2009 | 10:19 AM
Neal 97 250's Avatar
Neal 97 250
They are the same mod. Just two different names or references. The BB mod is also shimming the FPR with a BB.
If you need a good pic send me your e-mail address. I have a good pic but can't post it here because it is a word document.
Old Mar 10, 2009 | 10:54 AM
RRranch's Avatar
RRranch
Well, I answered my own question once I went out and pulled it apart for myself. I did the 3/16 ball bearing ( BB mod).
It's not as straight forward as everyone seems to think but thankfully I'm a machinist and gunsmith. The inside bore of the plunger was nowhere near big enough, mostly do to rough machine marks inside, to take a 3/16 ball bearing.
I took it over to my lathe and used a 3/16 reamer to fix it. The ball goes in easy now.
ALSO, My truck starts SO MUCH BETTER!
Before there was always a 3 or 4 second crank time, now it's near instant. The idle feels nearly the same as my 97 which has always run perfect, it's smoother, Much quicker windup and I'm about to go take off my slide in camper and go for a test drive to see how much more power I have.
Before fuel pressure was about 50 psi at idle which I have read is borderline for them. And about 65-70 at full throttle.
Now it is 65-70 idle and around 85 or so at 2500. The engine is cold so I didn't run it up on the governor just yet. By all the specs I have read this pressure range seems much better so it should be good to go now.
pauljackmax610
24
Jul 15, 2012 10:45 PM
whitesdford
22
Oct 23, 2009 05:25 PM
Aberasturi_c
16
Mar 25, 2008 11:00 AM
powerstroke 96`
Feb 21, 2008 03:38 PM
bigpowerstroke
Jun 16, 2004 06:49 PM
