pass side power window problem....
Old Mar 9, 2009 | 06:13 PM
nodoubt's Avatar
nodoubt
takes spells and only wants to go up, not down.....one minute it will work from the master panel on the drivers side, then not....was doing that for several rounds ONLY when the driver side door was completly open, and nothing at all from the driver side when the door was shut........it has ALWAYS rolled up from both sides every time, just having the intermittant demon on the roll down....bout to buffalo me here......motor sounds strong and is as fast as day one....????? any ideas.....???? thanks for the help....
Old Mar 9, 2009 | 06:32 PM
ron's power stroke's Avatar
ron's power stroke
pull the boot from the driver door post to the door and check for a broken wire..i went though relays and switches before i found it was just a broken wire in there.. ..
Old Mar 10, 2009 | 10:02 PM
nodoubt's Avatar
nodoubt
tx ron......ill have a look there....
Old Mar 11, 2009 | 09:58 AM
vettdvr's Avatar
vettdvr
You can pull easily the window panel of ds door and check the window switch. I found on my power mirrors the plug wasn't fully plugged in.
Old Mar 11, 2009 | 10:18 AM
1999SuperDutyStroke's Avatar
1999SuperDutyStroke
I am actually having the same problem with my drivers side door but mine will go up if i put pressure downward on the glass. I talked to JD, Ziggy, and Neal all last night about it, still havent figured out what is causing it but i did figure out if i unplug the motor and push the up button as i plug the motor back up it will go up. Maybe something for you to try.
Old Mar 11, 2009 | 10:57 AM
vettdvr's Avatar
vettdvr
This sounds like a bad motor with brushes that are sticking. Sticking brushes will sometimes not work and make you think you have wiring issues when it is actually a motor that needs replacing. BTDT many times on fords back to 84.
Old Mar 11, 2009 | 12:54 PM
1999SuperDutyStroke
Thanx anyone got a spare laying around!!!
