Limited progress
Old Mar 9, 2009 | 11:13 AM
tip49's Avatar
tip49
Limited progress
worked on the truck yesterday; -20 C so limited progress. I fastened the box to rails, alignment is suspect, parallel to frame, same distance of front of box to cab, looks like frame is 1/2" out front to back, or else my rear cross member got welded in crooked. anyway, Im going to re-align my rear axle today, I was out about 3/8" to passenger side, leaving uneven spacing of rear tires to box sides. Also, passenger side was slightly higher than driver side, so a couple steps back before moving ahead again.
Later
Tom
Old Mar 9, 2009 | 04:15 PM
Stephen67's Avatar
Stephen67
lol did a lot more than I did in those temps. Couple years ago I had to run heaters all day in my shop just so it could get warm enough for things to set. Nothing like working with 4 coats on
Looking forward to pictures when you're all done!
Old Mar 9, 2009 | 04:52 PM
thepitshop's Avatar
thepitshop
Originally Posted by tip49
worked on the truck yesterday; -20 c so limited progress. I fastened the box to rails, alignment is suspect, parallel to frame, same distance of front of box to cab, looks like frame is 1/2" out front to back, or else my rear cross member got welded in crooked. Anyway, im going to re-align my rear axle today, i was out about 3/8" to passenger side, leaving uneven spacing of rear tires to box sides. Also, passenger side was slightly higher than driver side, so a couple steps back before moving ahead again.
Later
tom
limited progress is beter than no progress!!
Old Mar 22, 2009 | 03:38 PM
tip49's Avatar
tip49
Another up date
Got the rear axle back in truck Friday; a lot of work by own self. Today is marking fender bolt locations. I'm excited to see the fenders go on, be a long time.
Later
Tom
Old Mar 22, 2009 | 05:31 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Way to go Tom!!
You're making better progress than I am. I haven't touched my truck in months
Keep it up
Bobby
Old Mar 22, 2009 | 09:16 PM
tip49's Avatar
tip49
Thanks Bobby.........but yours is moving under its own power. Hope to be there sometime this summer, then final paint next winter. Can't wait.
Tom
Old Apr 3, 2009 | 10:03 PM
tip49's Avatar
tip49
Fender bolts
filed holes square and welded in fender bolts today; also started mounting SS trim to grill. It ain't perfect but looks better than it did 4.5 years ago.
Looking forward to spring, to air out the beast.
Tom
Old Apr 4, 2009 | 03:18 PM
bigblockfordman's Avatar
bigblockfordman
Hey Tom, nice progress on your 50'!!........I enjoyed your gallery pic's as well!!.....I know how your "feel'n" about the weather, and how it really puts a "damper" on ones outdoor activitys!........(being from "northern" Mn.).....but somehow we do what we can, while we wait for our approx. 3 months or so of "warmer" weather!!!.....hahaha!....good luck with your build!.............
Later, Doug
Old Apr 6, 2009 | 07:13 AM
tip49's Avatar
tip49
Update
Managed to work a little on truck yesterday; finally completed the filler neck to my gas tank. I'm using Mustang tank, had to fab up the filler neck at 35 degrees angle, to make it level with the bed. It will sit so that the gas cap is flush to top of bed. I'd lke to have it under the bed but there was limited room. Still need to fab up return gas line to tank, probably into the sender opening. I might take pics today.
Later
Tom
Old Apr 6, 2009 | 07:47 AM
bobbytnm's Avatar
bobbytnm
Tom,
Sounds like good progress.
I cleared a path in my garage and drove my truck out into the light on Sunday. It was a nice day so I drove it to run my errands. While at the hardware store a guy in a 56 Packard started talking with me, the next thing I know I'm at his house looking at his stuff. He has a 1925 GMC (Chevy powered but riding on a 48 F1 axle), also had a 1917 Republic (all stock), a 56 T-bird, a 58 Packard and another 56 packard.
Its amazing how many friends you make when you drive an old truck.
Bobby
Old Apr 6, 2009 | 08:37 AM
tip49's Avatar
tip49
I hear that Bobby; I have met some really interesting people with this
re-build. Great minds.. and all that.
Old Apr 6, 2009 | 09:34 PM
tip49's Avatar
tip49
yet a little more work done
Managed to dismantle and paint heater today, bought 12 v blower moter as recommended by FTE. Also did some filler work on cab. Good productive day,
Now back to work for 10 days.
Old Apr 6, 2009 | 11:30 PM
woodyf1's Avatar
woodyf1
good work we should hook up if your ever in edmonchuk pm me
