cat and air pump
Old Mar 8, 2009 | 09:32 PM
nerraw117's Avatar
nerraw117
cat and air pump
What size belt do I need to remove my air injection pump on a 88 5.0? and I have a hole in my cat and I was wanting to just remove the cat but cannot find a cheap y-pipe to turn the pipe before the cat to something I can adapt to a single pipe.
Old Mar 8, 2009 | 09:43 PM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Either buy a smog pump eliminator pulley, or do what I did and take the smog pump apart and gut it. Running a shorter belt is a half-assed solution, do whatever you can to keep the stock size belt.
Get a Magnaflow y-pipe from Autoanything. They are $26.83, the link below brings it to the page to purchase one.
Magnaflow Y-Pipes
Old Mar 8, 2009 | 09:51 PM
nerraw117's Avatar
nerraw117
So I just cut off the flange before the cat and weld or clamp it on there? and where can I get a bypass pulley autozone?
Old Mar 8, 2009 | 10:34 PM
Dirt racer's Avatar
Dirt racer
I recently took off my smog pump on my 92 F150 5.0. I used Gates part number K060878. It is 88 and1/2 inches long. Was a little on the tight side. But fit. Haven't had any problems with it. Thanks 1994 F250:351,C6 for the Y pipe link. I was looking for one of those also. Going to build a better exhaust system when it warms up.
