body bushing help
Old Mar 8, 2009 | 08:46 PM
mudder460's Avatar
mudder460
body bushing help
Ok, I finally got around to putting in my new body bushings. I was able to get to radiator support ones swapped with moderate cussing. Now I am onto the main body, but how do you get them apart? There isn't much room to get an air hammer in the little spot for the front cab bushings. I know they are pressed in, just need some help to get them out.
Old Mar 8, 2009 | 09:00 PM
bmuhlbach's Avatar
bmuhlbach
when i did mine the bolts were rested I SAW zawed thru them and jacked up the side of the cab with a 4x4 on a floor jack one side at a time.
Old Mar 8, 2009 | 09:41 PM
kshaneh's Avatar
kshaneh
i did the same exact thing, eccept for the 4x4, i just rrolled my cab off and onto the ground
Old Mar 8, 2009 | 10:05 PM
mudder460's Avatar
mudder460
Now I have another question. I noticed the price of the sleeves and it is pretty crazy. Can I just get some grade 8 bolts say 5/8" thick and use them instead? Should work the same as the sleeves right?
