Chugging up the mountain/P0603 code
Old Mar 8, 2009 | 06:06 PM
danocross's Avatar
danocross
Went back north in the Arizona mountains for a ski trip/truck check, I was experiencing what I think was turbo farting so I wanted more objective info. Everything was ok on flat land, as soon as I started to climb, I was basically chugging up the passes, blowing out a puff of black smoke with each "chug." I went to a Ford dealer in a small town, the tech tested the truck and found a P0603 code, and "low inj cir." He said he reprogrammed the FICM module and thought that would solve things. I got through the biggest passes coming home with no problems, but then a smallish climb produced about 8 big "chugs" with a big puff of black smoke each chug, 65mph and 2200 rpms (I don't have gauges). The rest of the ride was uneventful.
Any ideas? I cleaned up the EGR valve 5000 miles ago (it was in good shape), and the fuel filters aren't due for another 5000 miles. I am going back to the local dealer in the morning to see if any codes show up. No CEL either...
Old Mar 9, 2009 | 10:41 AM
steelhead2's Avatar
steelhead2
i would say your egr valve is sticking on you. when mine stuck it produced the same problem. would buck and blow black smoke when i would put a load on it. i cleaned my valve and it looked new, but it was sticking open.i also had an inj #1 low circuit code but know cel.......
Old Mar 9, 2009 | 12:03 PM
danocross's Avatar
danocross
Thanks Steel...so did cleaning the EGR valve then solve your problem?
Dan
Old Mar 9, 2009 | 12:35 PM
brickie's Avatar
brickie
The EGR has a 30ish lb spring that keeps it closed,it sounds to me like your spring is old and tired.
Old Mar 9, 2009 | 01:41 PM
danocross's Avatar
danocross
Good info, Brickie. Ford replaced the EGR valve 13,000 miles ago, stupid question-is the spring part of the valve?
Dan
Old Mar 9, 2009 | 01:55 PM
hangon2me's Avatar
hangon2me
Mine did the same thing from day one when it was new. I blocked off that POS and never had the problem again.
Old Mar 9, 2009 | 05:56 PM
danocross's Avatar
danocross
Went to Ford and they are going to take the turbo apart under warranty and check it out. The tech felt the main problem was in the turbo, but he is also going to replace the EGR valve. I don't think I had these chugging problems until the PCM was reprogrammed, but what do I know.
