10A easy access hot wire location
Old Mar 8, 2009 | 09:24 AM
Mulepick's Avatar
Mulepick
Came across this while perusing a Ford Fleet site:
Q17: Where is circuit 294 (White with Light Blue stripe) on 2005 F-250/350/450/550 trucks? (12 volt ignition hot source fused for 10 amps)
A17: Circuit 294 (W/LB) can be found by following the harness from the diagnostic connector at the lower edge of the dash on the driver's side. Circuit 294 (W/LB) is half way up the harness and is blunt cut with shrink wrap on the wire.
Bob
Old Mar 8, 2009 | 09:45 AM
b2747's Avatar
b2747
Talking
Bob
Thanks Bob, That is great Info. Shure makes this project go easy, Thanks again.
